[OpenLayers-Users] Can't transform lat/long to a projection
Eric Lemoine eric.lemoine at camptocamp.com
Mon Jul 13 11:45:09 EDT 2009
On Monday, July 13, 2009, winfield.dave <winfield.dave at gmail.com> wrote:
> Hi all,
> Essentially, I'm having a problem converting some lat/long values I get back
> from a webservice onto my map. The map is using EPSG:3395, so I thought code
> like this would work.
> <!-- at the top -->
> var latLonProj = new OpenLayers.Projection("EPSG:4236");
> var osmProj = new OpenLayers.Projection("EPSG:3395");
> <!-- code that matters -->
> var markers = new OpenLayers.Layer.Markers( "Markers" );
> map.addLayer(markers);
> var ll = new OpenLayers.LonLat(51.644715, -0.0327);
> ll.transform(latLonProj, osmProj);
> <!-- code for the icon and adding to the map -->
> var size = new OpenLayers.Size(10,17);
> var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
> var icon = new
> OpenLayers.Icon('http://boston.openguides.org/markers/AQUA.png',size,offset);
> markers.addMarker(new OpenLayers.Marker(ll,icon));
> I can do an alert on the ll.lon and ll.lat values AFTER the transform and
> they're the same as what I passed into the constructor.
> I thought maybe I had the lon/lat values reversed, so I changed the order of
> the parameters in the LonLat constructor, but it did not help.  I was also
> under the impression that EPSG:4236 was the geographic coordinates, but I
> could be wrong.
> Any thoughts?
Hi. Do you have proj4js loaded? And is the EPSG:3395 projection
defined in proj4js?
Cheers,
> View this message in context: http://n2.nabble.com/Can%27t-transform-lat-long-to-a-projection-tp3250372p3250372.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
