[OpenLayers-Users] Plotting a KML layer in a map that uses a
different projection
Richard Marsden
richard at winwaed.com
Mon Jul 13 20:14:49 EDT 2009
Hello,
I am developing a map that uses a non-cylindrical projection (Mollweide
in this case but I'll probably use other pseudo-cylindrical projections
later). I have OpenLayers displaying this properly with tiles delivered
by WMS (from MapServer).
I would now like to add extra layers from KML, and possibly GeoRSS.
Of course when I add a KML layer then the KML coordinates (geographic
WGS84 as per the spec) are plotted as if they are metric cartesian
coordinates in Mollweide space.
For individual coordinates, I know I can transform them one at a time
using the OpenLayers.Projection.transform( ) method (this may prove
useful later - eg. if I implement my own simple graticule).
However, I would like to transform the entire KML layer. How can I do this?
I've tried cribbing from the example at:
http://openlayers.org/dev/examples/sundials-spherical-mercator.html
and this doesn't make any difference.
(yes Proj4JS is loaded and I have the Mollweide EPSG code defined - the
base WMS layer is plotting fine!)
I really do not want to go through the KML file and parse it element by
element. Although my current test data is pushpin/marker based, I would
like a reasonably general case that also works with polylines, polygons,
etc.
Transforming into a "Mollweide KML" format isn't an option either -
this should be a general case with a user-supplied KML file.
Who do other people do in this situation? Or is the above example broken?
Richard (M)
