[OpenLayers-Users] Overriding overlay select to force a reload
of the toggled layer
Adrian Popa
adrian_gh.popa at romtelecom.ro
Thu Jul 16 08:41:09 EDT 2009
Hello Jay,
Thanks for your help. I ended up doing:
markers.events.on({ "featureselected": onMarkerSelect,
"featureunselected": onMarkerUnselect, *"visibilitychanged":
onMarkerToggle* });
function onMarkerToggle(event)
//ask for this layers refresh if visibility becomes
true
if(markers.visibility ==
true){
// alert("requesting marker
refresh");
updateActiveAlarms(); //this refreshes the layer
It works perfectly. Thanks again,
Adrian
Jay Douillard wrote:
> Adrian,
> You need to register events to fire when want refreshing to occur.
> You can use the visibility property of a layer to test if it is visible and only refresh those layers that are.
> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Layer-js.html#OpenLayers.Layer.visibility
> http://dev.openlayers.org/apidocs/files/OpenLayers/Events-js.html
> Jay
> ----- Original Message -----
> From: "Adrian Popa" <adrian_gh.popa at romtelecom.ro>
> To: users at openlayers.org
> Sent: Tuesday, July 14, 2009 11:27:17 PM GMT -08:00 US/Canada Pacific
> Subject: [OpenLayers-Users] Overriding overlay select to force a reload of the toggled layer
> Hi everybody,
> I have several overlay vector layers that get their data in KML format
> from some server-side scripts. The data is highly dynamic, so it needs
> to be refreshed constantly (this is solved). The problem appears if only
> one overlay layer is selected (visible), I need to refresh all overlay
> layers so that if the user toggles another overlay, he will have the
> most recent data. I would like to reduce the overhead on the server and
> client side and only refresh the visible overlay layers, and to force a
> refresh of a layer whenever the user makes it visible. For this I would
> have to override the function that runs when a layer is selected in the
> layer switcher and call another refresh function before the layer is
> made visible. Can anyone point me in the right direction?
> P.S. I would like to do this without editing the openlayers code;
> instead I would like to override/overload the function for my objects only.
> Thanks,
> Adrian
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090716/4414839a/attachment.html
