[OpenLayers-Users] Problems upgrading between 2.7 and 2.8...
Steve Lime Steve.Lime at dnr.state.mn.us
Thu Jul 16 14:18:41 EDT 2009
The measure interface looks very similar to 2.7, nothing is obvious. It seems like the 'measure' event isn't being
invoked when shift-dragging and you release the mouse. It is in 2.7.
Steve
>>> On 7/16/2009 at 11:35 AM, in message <4A5F56D1.7090600 at osgis.nl>, "Bart van den
Eijnden (OSGIS)" <bartvde at osgis.nl> wrote:
> Steve,
> it seems like you did not copy the theme directory, so a bit of css is
> missing?
> Yes indeed, the measure interface has changed, please check
> examples/measure.html for hints on how to fix that. If you can't get it
> to work, please report back.
> Best regards,
> Bart
> Steve Lime wrote:
>> Hi all: Just trying 2.8 with an app developed with 2.7 and have a problem
> where the zoom box (shift-drag) and overview map rect aren't
>> displaying (zoom works though). Figure it's a z-index issue. Any idea what
> might have changed between versions? App is:
>>   http://maps.dnr.state.mn.us/compass_test/compass_full.html  (2.8) and
>>   http://maps.dnr.state.mn.us/compass_test/compass_full_2.7.html (2.7)
>> I've also noticed the measureControl doesn't seem invoke callbacks in the
> same way as 2.7. This is most noticeable when scribbling (shift-drag).
>> Steve
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
