[OpenLayers-Users] Events on text labels
Paul Spencer
pagameba at gmail.com
Fri Jul 17 09:58:28 EDT 2009
On 17-Jul-09, at 9:28 AM, Tamlyn Rhodes wrote:
>> oh, sorry didn't see that. I haven't tried that patch so I can't
>> comment on
>> it :)
> I tried applying just your patch to a fresh copy of OpenLayers-2.8 but
> I still can't get it to work. I'm sorry, I'm probably being dumb.
> Could you perhaps provide a simple example of making a label clickable
> using your patch?
difficult to debug ... here is what I would do:
* confirm that I am using the OpenLayers source that I think I am
using (if using a single file build, make sure the single file is
built with the patches)
* confirm using firebug that the changes are actually in the source code
* set a breakpoint in getFeatureIdFromEvent (Elements.js) and see if
evt.target is the right thing (a textbox node) and that it has a
_featureId property (which is what is returned and which makes the
selection work).
Cheers
Paul
