[OpenLayers-Users] Dynamic display line follow line route
shane_china
xiaying4415139 at 163.com
Tue Jul 21 14:38:02 EDT 2009
I spend hours to finish the simplest implement. The following is the code,
here I used another person's lib to calculate the distance and point on
earth, see method "getPointOnLineByDistance" and the attached file
"Point.js". Now it just support LineString, I'll add more functionalities,
"start stop suspend" for example, and some event listeners in the furture.
Hope your suggestions.
function Point (x, y) {
this.x = parseFloat(x);
this.y = parseFloat(y);
Point.prototype = new OpenLayers.Geometry.Point(0,0);
Point.prototype.isValid = function() {
if((this.x != null) && (this.y != null) && (this.x != NaN) && (this.y !=
NaN))
return( true );
else
return( false );
Point.prototype.geoIsValid = function() {
if( this.isValid() && (this.x >= -180) && (this.x <= 180) && (this.y >=
-90) && (this.y <= 90))
return( true );
else
return( false );
* Geo Constants
// Point.EARTH_RADIUS = 3958.75; // in miles
Point.EARTH_RADIUS = 6370.856; // in km
Point.DEG2RAD = 0.01745329252; // factor to convert degrees to radians
(PI/180)
Point.RAD2DEG = 57.29577951308;
* Method: geoDistanceTo
* Parameters:
* point - {<Point>}
* Returns:
* Great Circle distance (in miles) to Point.
* Coordinates must be in decimal degrees.
* Reference:
* Williams, Ed, 2000, "Aviation Formulary V1.43" web page
* http://williams.best.vwh.net/avform.htm
Point.prototype.geoDistanceTo = function( point ) {
var x = [];
var y = [];
if( this.geoIsValid() && point.geoIsValid()) {
x[0] = this.x * Point.DEG2RAD; y[0] = this.y * Point.DEG2RAD;
x[1] = point.x * Point.DEG2RAD; y[1] = point.y * Point.DEG2RAD;
var a = Math.pow( Math.sin(( y[1]-y[0] ) / 2.0 ), 2);
var b = Math.pow( Math.sin(( x[1]-x[0] ) / 2.0 ), 2);
var c = Math.pow(( a + Math.cos( y[1] ) * Math.cos( y[0] ) * b ),
0.5);
return ( 2 * Math.asin( c ) * Point.EARTH_RADIUS );
} else
return null;
Point.prototype.geoBearingTo = function( point ) {
var x = new Array(2);
var y = new Array(2);
var bearing;
var adjust;
var a = Math.cos(y[1]) * Math.sin(x[1] - x[0]);
var b = Math.cos(y[0]) * Math.sin(y[1]) - Math.sin(y[0])
* Math.cos(y[1]) * Math.cos(x[1] - x[0]);
if((a == 0) && (b == 0)) {
bearing = 0;
return bearing;
if( b == 0) {
if( a < 0)
bearing = 270;
else
bearing = 90;
return bearing;
if( b < 0)
adjust = Math.PI;
else {
if( a < 0)
adjust = 2 * Math.PI;
else
adjust = 0;
bearing = (Math.atan(a/b) + adjust) * Point.RAD2DEG;
return bearing;
} else
return null;
Point.prototype.geoWaypoint = function( distance, bearing ) {
var wp = new Point( 0, 0 );
// Math.* trig functions require angles to be in radians
var x = this.x * Point.DEG2RAD;
var y = this.y * Point.DEG2RAD;
var radBearing = bearing * Point.DEG2RAD;
// Convert arc distance to radians
var c = distance / Point.EARTH_RADIUS;
wp.y = Math.asin( Math.sin(y) * Math.cos(c) + Math.cos(y) * Math.sin(c)
* Math.cos(radBearing)) * Point.RAD2DEG;
var a = Math.sin(c) * Math.sin(radBearing);
var b = Math.cos(y) * Math.cos(c) - Math.sin(y) * Math.sin(c) *
if( b == 0 )
wp.x = this.x;
else
wp.x = this.x + Math.atan(a/b) * Point.RAD2DEG;
return wp;
Julien-Samuel Lacroix wrote:
> Hi,
> I don't recall to have seen any example of this before. You can probably
> start looking here [1] for vector construction and here [2] for
> JavaScript timing event. Start really simple with only 2 points and then
> try to include your multiline. If you have it working at some point let
> us know. I would be curious to see it working.
> [1] http://openlayers.org/dev/examples/vector-features.html
> [2] http://www.w3schools.com/js/js_timing.asp
> Julien
> shane_china wrote:
>> Is there anyone can help me? thank you.
> Mapgears
> http://www.mapgears.com/
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Dynamic-display-line-follow-line-route-tp3279524p3295288.html
