[OpenLayers-Users] Problem with geometry in OL
Andreas Hocevar
ahocevar at opengeo.org
Wed Jul 22 05:00:16 EDT 2009
Rohan Patel wrote:
> Hi Andreas,
> That looks pretty good but how do I add vectorLayer to the map?
map.addLayer(vectorLayer);
You will probably want to make the map globally available also (like in
the examples).
Regards,
Andreas.
> Thanks,
> Rohan
> -----Original Message-----
> From: Andreas Hocevar <ahocevar at opengeo.org>
> To: Rohan Patel <rohan at quintemri.com>
> Cc: users <users at openlayers.org>
> Date: Tue, 21 Jul 2009 19:52:09 +0200
> Subject: Re: [OpenLayers-Users] Problem with geometry in OL
> Rohan Patel wrote:
> > Hi Andreas,
> > Well I have vectorLayer initialized in my init().
> > I am not that great with javascript, java is actually my forte. Do I
> > need to make vectorLayer public or something?
> Something like that, yes.
> You now have
> function init() {
> var vectorLayer = ...;
> function test() {
> alert(typeof vectorLayer); // "undefined"
> So vectorLayer is only known to the init method. Instead, you will
> want:
> var vectorLayer;
> function init() {
> vectorLayer = ...;
> function test() {
> alert(typeof vectorLayer); // "Object"
> Regards,
> Andreas.
> > Thanks,
> > Rohan
> > To: maelstrom666 <rohan at quintemri.com>
> > Cc: users at openlayers.org
> > Date: Tue, 21 Jul 2009 15:13:54 +0200
> > Hi,
> > sounds like a scope issue. Is vectorLayer known to your test()
> > function? Use Firebug or your favorite debugger to find out.
> > Regards,
> > Andreas.
> > On Fri, Jul 17, 2009 at 2:14 PM,
> maelstrom666<rohan at quintemri.com>
> > wrote:
> > > Hi I am having some issues with geometry in OL.
> > > When I click a button, it activates a function which
> should add
> > a point to
> > > the map.
> > > Here is the code for that function:
> > > <script language="javascript" type="text/javascript">
> > > function test()
> > > var point2 = new OpenLayers.Geometry.Point(-101.04,
> 45.68);
> > > var pointFeature2 = new
> > OpenLayers.Feature.Vector(point2,null,style_blue);
> > > vectorLayer.addFeatures([pointFeature2])
> > > </script>
> > > in the function init, i have another point which shows up
> > without any issues
> > > here is an excerpt of tht code:
> > > var point = new OpenLayers.Geometry.Point(-111.04, 45.68);
> > > var pointFeature = new
> > OpenLayers.Feature.Vector(point,null,style_blue);
> > > vectorLayer.addFeatures([pointFeature]);
> > > If you need more code or anything please tell me.
> > > Thanks,
> > > Rohan
> > > View this message in context:
> http://n2.nabble.com/Problem-with-geometry-in-OL-tp3275045p3275045.html
> > > Sent from the OpenLayers Users mailing list archive at
> Nabble.com.
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> > Andreas Hocevar
> > OpenGeo - http://opengeo.org/
> > Expert service straight from the developers.
> Andreas Hocevar
Andreas Hocevar
