[OpenLayers-Users] WFS server response OK, but not appearing
Maxime Phaneuf maxime.phaneuf at usherbrooke.ca
Fri Jul 24 12:38:34 EDT 2009
Hi list
I  am working on WFS-T currently, and I based my project on
http://openlayers.org/dev/examples/wfs-protocol-transactions.html.
My problem is that the WFS loads correctly. I can see the GML response in
firebug. But, the layer is not appearing on the map at all.
Here is the .html:
        function init() {
            OpenLayers.ProxyHost = "../cgi-bin/proxy.cgi?url=";
            map = new OpenLayers.Map('map', {
                projection: new OpenLayers.Projection("EPSG:27582"),
				maxExtent: new OpenLayers.Bounds(5638.000000,1620431.000000,
1197822.000000,2677441.000000),
				maxResolution: (2677441 - 1620431)/512,
                units: "m",
                controls: [
                    new OpenLayers.Control.PanZoom()
			var wms = new OpenLayers.Layer.WMS("France",
			"http://www.geosignal.org/cgi-bin/wmsmap?", {layers: 'regions',
srs:'EPSG:27582', format:'image/png'}, {buffer: 0});
            var saveStrategy = new OpenLayers.Strategy.Save();
            wfs = new OpenLayers.Layer.Vector("France", {
                strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
                protocol: new OpenLayers.Protocol.WFS({
					version:       "1.0.0",
					url:           "http://**.***.**.***/cgi-bin/tinyows",
					featureType:   "france_dept",
					srsName:       "EPSG:27582",
					featureNS:     "**.***.**.***",
					//featurePrefix: "tows",
					geometryName:  "the_geom",
					schema:
"http://**.***.**.***/cgi-bin/tinyows?service=WFS&version=1.0.0&request=DescribeFeatureType&TypeName=tows:france_dept"
            var panel = new OpenLayers.Control.Panel(
                {'displayClass': 'customEditingToolbar'}
            var navigate = new OpenLayers.Control.Navigation({
                title: "Pan Map",
            var draw = new OpenLayers.Control.DrawFeature(
                wfs, OpenLayers.Handler.Polygon,
                    title: "Draw Feature",
                    displayClass: "olControlDrawFeaturePolygon",
                    handlerOptions: {multi: true}
            var edit = new OpenLayers.Control.ModifyFeature(wfs, {
                title: "Modify Feature",
                displayClass: "olControlModifyFeature",
            var del = new DeleteFeature(wfs, {title: "Delete Feature"});
            var save = new OpenLayers.Control.Button({
                title: "Save Changes",
                trigger: function() {
                    if(edit.feature) {
                        edit.selectControl.unselectAll();
                    saveStrategy.save();
                displayClass: "olControlSaveFeatures"
            panel.addControls([navigate, save, del, edit, draw]);
            panel.defaultControl = navigate;
			map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.addControl(panel);
			map.addLayers([wms, wfs]);
			//map.setCenter(new OpenLayers.LonLat(-59457,1374886),1);
            map.zoomToMaxExtent();
The WFS server is TinyOWS. I don't think this is the problem beacuase when I
do a getfeature request in firefox, I get a valid GML response.
Do you see what I'm doing wrong here because I can't? hehe
Thank you and have a nice weekend.
Maxime Phaneuf
View this message in context: http://n2.nabble.com/WFS-server-response-OK%2C-but-not-appearing-tp3316670p3316670.html
