[OpenLayers-Users] JS code in external script
Shawn Oatley
shawn at niagarafalls.ca
Sun Jul 26 09:31:47 EDT 2009
It's a lttle bit hard to tell here, but it looks like you have an extra closing bracket at the bottom. You should try Firebug and see if it reports any errors in the console. Plus, in firebug, you can check out the scripts tab and see if all the scripts are actually loaded (proper file paths, etc..).
Shawn
>>> On 7/25/2009 at 5:16 PM, Nicholas Efremov-Kendall <n.e.kendall at gmail.com> wrote:
Hi all,
the application I've been developing relies on the OL url API, Openstreet map (for now etc). I have one version where the code is written in-line, one version where the code is in an external script. The in-line code works fine, but the external script has misalignment issues. I have no idea why this is happening, does anyone have any suggestions?
These are all included in my header file
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
<script src="http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
<script src="js/OpenLayers-2.7/proj4js-combined.js"></script>
<script language="javascript" type="text/javascript" src="js/mapsettings2.js"></script>
and here is my code, note it is exactly the same as the in-line version.
var map, layer, selectedFeature, selectControl, selectedFeature;
var lat = 10.87;
var lon = 33.79;
//Popups
function onPopupClose(evt) {
selectControl.unselect(selectedFeature);
function onFeatureSelect(feature) {
selectedFeature = feature;
popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
null,
"<div style='font-size:.8em'>Site_ID: " + feature.attributes.title +"<hr />Locality: " + feature.attributes.title+"<br/>Description: " +feature.attributes+"<br/> Feature ID: "+feature.id+"<br/>Feature Type:"+feature.attributes.NEWSITE_ +"</div>",
null, true, onPopupClose);
feature.popup = popup;
map.addPopup(popup);
function onFeatureUnselect(feature) {
map.removePopup(feature.popup);
feature.popup.destroy();
feature.popup = null;
//Map Constructor
function init() {
map = new OpenLayers.Map ("map",
controls:[
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.LayerSwitcher(),
new OpenLayers.Control.Attribution()],
sphericalMercator: true,
maxExtent: new OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
maxResolution: 156543.0399,
numZoomLevels: 19,
units: 'm',
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
//Map Data
//Base Layers
var layerMapnik = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
map.addLayer(layerMapnik);
var ol_wms = new OpenLayers.Layer.WMS( "World Map",
"http://labs.metacarta.com/wms/vmap0", {layers: 'basic', format: 'image/png' } );
// Overlays
var topo = new OpenLayers.Layer.GML("Jerba Topography",
"data/topopj.gml", {styleMap: new OpenLayers.StyleMap({strokeWidth: 1, strokeColor: "#000000"}) });
map.addLayer(topo);
var sites = new OpenLayers.Layer.GML(
"Sites", "data/siteswatr.gml", {styleMap: new OpenLayers.StyleMap({pointRadius: 2.5, fillColor: "#"},
{projection: new OpenLayers.Projection("EPSG:32632")})});
map.addLayer(sites);
var outline = new OpenLayers.Layer.GML("Jerba Island", "data/outline.gml");
map.addLayer(outline);
//Map Controls Should theoretically be in map constructor, but only navigation works
map.addControl( new OpenLayers.Control.LayerSwitcher());
map.addControl( new OpenLayers.Control.MousePosition());
map.addControl( new OpenLayers.Control.OverviewMap());
map.addControl( new OpenLayers.Control.ScaleLine());
//map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
//highlighting stuff
var report = function(e) {
OpenLayers.Console.log(e.type, e.feature.id);
var highlightCtrl = new OpenLayers.Control.SelectFeature(sites, {
onSelect: onFeatureSelect,
onUnselect: onFeatureUnselect,
hover: true,
highlightOnly: true,
renderIntent: "temporary",
eventListeners: {
beforefeaturehighlighted: report,
featureunhighlighted: report
var selectCtrl = new OpenLayers.Control.SelectFeature(sites,
{clickout: true}
map.addControl(highlightCtrl);
map.addControl(selectCtrl);
highlightCtrl.activate();
selectCtrl.activate();
// set center from geometry
if( ! map.getCenter() )
topo.events.register('loadend', topo, function(){map.zoomToExtent(topo.getDataExtent())});
map.setCenter(null, null);
else
map.setCenter(new OpenLayers.LonLat(lon, lat));
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090726/e3c29498/attachment.html
