[OpenLayers-Users] Problems implementing WFS
Maxime Phaneuf
maxime.phaneuf at usherbrooke.ca
Mon Jul 27 16:09:05 EDT 2009
Hi guys
I've got the same problem as Hugo. My WFS layer would not appear on the map,
even though I've got a ok server response.
My layer looks like this:
wfs = new OpenLayers.Layer.Vector("France", {
strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
protocol: new OpenLayers.Protocol.WFS({
version: "1.0.0",
url: "http://mydomain/cgi-bin/tinyows",
featureType: "france_dept",
srsName: "EPSG:24582",
featurePrefix: "tows",
//featureNS: "http://mydomain",
geometryName: "the_geom",
schema:
"http://mydomain/cgi-bin/tinyows?service=WFS&version=1.0.0&request=DescribeFeatureType&TypeName=france_dept",
Define like this, the layer will show up, but any modification can't be
saved. When I take off the comments of featureNS, it will not show up, so I
suppose it is an error caused by the namespace.
I've tried putting a breakline where you told but it doesn't even stop when
I reload the page.
What is the correct value to put for featureNS? Or do you see anything else
wrong with my layer definition?
Thank you
Maxime Phaneuf
Hugo-2 wrote:
> Hi Alexandre,
> Thanks for your help. Indeed it was a problem with the namespace. A dummy
> mistake :)
> Kind regards,
> Hugo Martins
> On Tue, Jun 30, 2009 at 1:00 PM, Alexandre Dube <adube at mapgears.com>
> wrote:
>> Hi Hugo,
>> This looks like a feature namespace problem. See the Format.XML
>> readNode
>> function, put a break point at line :
>> var group = this.readers[this.namespaceAlias[node.namespaceURI]];
>> This might be the problem,
>> Alexandre
>> Hugo wrote:
>>> Hello all,
>>> I'm having troubles to implement a vector layer with WFS protocol. From
>>> firebug i can see that the attributes from the layer are extracted,
>>> however
>>> no vector feature is displayed in the map.
>>> DO you have any suggestions??? My code is as follows:
>>> var saveStrategy = new OpenLayers.Strategy.Save();
>>> var wfs2 = new OpenLayers.Layer.Vector(
>>> "ExplorWFS2",
>>> saveStrategy],
>>> projection: wgs,
>>> version: "1.1.0",
>>> srsName: "EPSG:4326",
>>> url: "http://isegi.dyndns.org:8080/geoserver/wfs?",
>>> featureNS : "http://isegi.dyndns.org:8080/sigla",
>>> featureType: "explor",
>>> schema: "
>>> http://isegi.dyndns.org:8080/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=sigla:explor<
>>> format: new OpenLayers.Format.WFST.v1_1_0({
>>> featureType: 'explor',
>>> featureNS: "http://isegi.dyndns.org:8080/sigla",
>>> featurePrefix: 'sigla',
>>> geometryName: 'the_geom'
>>> I have tried these code with and without the format option.
>>> If i simply use the following code, everything goes perfect and vector
>>> features are displayed in the map:
>>> var wfs = new OpenLayers.Layer.WFS(
>>> "ExplorWFS",
>>> {typename: 'sigla:explor'},
>>> featureVersion: "1.0.0",
>>> typename: 'explor',
>>> featureNS: '"http://isegi.dyndns.org:8080/sigla',
>>> projection: wgs,
>>> extractAttributes: true,
>>> schema: "
>>> Thanks in advance.
>>> Kind regards,
>>> Hugo Martins
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
> Users mailing list
View this message in context: http://n2.nabble.com/Problems-implementing-WFS-tp3176672p3336074.html
