[OpenLayers-Users] Error displaying map in IE8 - VML.js
soatley
shawn at niagarafalls.ca
Mon Jul 27 18:13:09 EDT 2009
I have a feeling I am running into the same issue here. I am using Revision
9492 and the problem I encounter is the Invalid Argument error when adding
vector layers to the map.
I have tried it on IE 7 (Win XP 32 bit) and IE 8 (Vista 64, in compatability
mode). IE 8 on Vista not in compat. mode works fine.
It seems to be very similar to the issue with Ticket 1910 from what I can
tell.... Setting up an IE breakpoint on line 600 of OpenLayers.js it breaks
where the variables w and h are assigned because this.size.w is NaN. If you
were to look at the VML.js file, it is in the area of line 154.
Does anyone have any new information or a way I can work around this?
Shawn
Christopher Schmidt-2 wrote:
> On Thu, Jun 18, 2009 at 10:23:15AM -0700, palewire wrote:
>> I've encountered some IE8 errors too. Here's the paste from what the
>> browser
>> gives you. Is there anything I can do to help out?
> What SVN version is this with? This should only have been fixed in the
> last few commits.
> -- Chris
>> Webpage error details
>> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1;
>> Trident/4.0)
>> Timestamp: Thu, 18 Jun 2009 17:21:04 UTC
>> Message: Invalid argument.
>> Line: 793
>> Char: 110
>> Code: 0
>> URI: http:// ... /openlayers/OpenLayers.js
>> Asle Benoni wrote:
>> > Sorry Christopher and others. That was a bad one from me. I did't like
>> > my attitude there.
>> > Of course I will test it since I had the problem just now. Glad you
>> > pointed that out since I am always so glad and amazed at people here
>> > just helping out ;-)
>> > Hope I can contribute also.
>> > /asle
>> > Den 12. juni. 2009 kl. 16.01 skrev Christopher Schmidt:
>> >> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
>> >>> Thanks Kenneth, the compatibility hack works fine. I would rather
>> >>> not hack
>> >>> VML.js but I see this hack is newer than the one I tried. As long
>> >>> as the
>> >>> quickfix works I am satisfied. But would like to know if some have
>> >>> success
>> >>> with it and if it is included in future OL release.
>> >> It can't be included in a future OL release until people test it. If
>> >> you're unwilling to test it, the chances it will be included decrease.
>> >> Please help test it if you care about it.
>> >> -- Chris
>> >>> /asle
>> >>> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
>> >>>> Hi,
>> >>>> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
>> >>>> A/S<ks at geograf.dk> wrote:
>> >>>>> Note sure what the actual problem is, but there are notes that
>> >>>>> the patch
>> >>>>> does not solve all issues.
>> >>>>> There is a nother fix mentioned, namely the one in comment #20:
>> >>>>> http://trac.openlayers.org/ticket/1910#comment:20
>> >>>>> This effectively places IE8 in IE7 compatibility mode, and it
>> >>>>> works.
>> >>>>> Although it's not the correct long term solution, you can use it
>> >>>>> until
>> >>>>> the issue is fixed more permanently.
>> >>>> The latest patch [1] should fix all vector layer issues in IE8. It
>> >>>> would be nice to get some feedback if this is really the case.
>> >>>> Regards,
>> >>>> Andreas.
>> >>>> [1]
>> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
>> >>>> Andreas Hocevar
>> >>>> OpenGeo - http://opengeo.org/
>> >>>> Expert service straight from the developers.
>> >>> _______________________________________________
>> >>> Users mailing list
>> >>> Users at openlayers.org
>> >>> http://openlayers.org/mailman/listinfo/users
>> >> Christopher Schmidt
>> >> MetaCarta
>> > Users mailing list
>> View this message in context:
>> http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3114656.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Christopher Schmidt
> MetaCarta
> Users mailing list
View this message in context: http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3336661.html
