[OpenLayers-Users] GetCapabilities
Marc Jansen
jansen at terrestris.de
Tue Jul 28 11:15:41 EDT 2009
Hi Raul,
getFullRequestString is actually a method of instances of e.g.
OpenLayers.Layer.WMS, so it should be called like this:
var wms_layer = new OpenLayers.Layer.WMS( ... );
wms_layer.getFullRequestString(
REQUEST: 'GetCapabilities'
'http://www.example.com/wms-server'
It is not a method of the Map-instance.
The second error you get (Access to restricted URI denied) hints that
you are trying to issue a AJAX Request to another server than the one
your script is being executed at.
For example it is not allowed for a script running on
http://abc.example.com to query http://xyz.example.com.
Regards,
Marc
Raul David Orozco schrieb:
> Hi. I'm trying to make a GetCapabilities request to a server, using a
> couple of examples that I found in OpenLayers documentation.
> In the first case I tried something like this:
> var url = map.getFullRequestString({
> REQUEST: "Getcapabilities"},
> "http://192.168.1.5:9090/smms/wms.php"); //URL of the
> server
> OpenLayers.loadURL(url, '', this, setHTML);
> but I get a error message saying that function getFullRequestString
> doesn't exists.
> In my second try, I used this code:
> this.request = OpenLayers.Request.GET({
> url: "http://192.168.1.5:9090/smms/wms.php",
> success: function(response)
> var XMLformat = new OpenLayers.Format.XML();
> xml = XMLformat.read(response.responseText);
> var CAPformat = new OpenLayers.Format.WMSCapabilities();
> capabilities = CAPformat.read(xml);
> window.console.log(capabilities);
> But I get the error related to the proxy:
> Access to restricted URI denied" code: "1012"
> Now I'm out of ideas, I don't know how to capture the GetCapabilities request.
> Thanks for any help, I'll appreciate it.
> ¡Obtén la mejor experiencia en la web!
> Descarga gratis el nuevo Internet Explorer 8
> http://downloads.yahoo.com/ieak8/?l=e1
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Diplom-Geograph Marc Jansen
- Anwendungsentwickler -
terrestris GmbH & Co. KG
Irmintrudisstraße 17
53111 Bonn
Tel: ++49 (0)228 / 96 28 99 -53
Fax: ++49 (0)228 / 96 28 99 -57
Email: jansen at terrestris.de
Web: http://terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH
vertreten durch: Hinrich Paulsen, Till Adams
