[OpenLayers-Users] Error displaying map in IE8 - VML.js
Andreas Hocevar ahocevar at opengeo.org
Wed Jul 29 11:57:22 EDT 2009
soatley wrote:
> In case anyone else runs into this, I found out that after the map is
> created, it sometimes doesn't set a height or width value in the map.size
> property.  Here's my fix which seems to work quite nicely:
>  map = new OpenLayers.Map('map', options);
> if (isNaN(map.size.w) || isNaN(map.size.h)) {
>             map.updateSize();
You can also make sure that the container where you render the map in
(in your snippet a div or whatever element with id 'map') has a width
and height style before you create the map object.
Regards,
Andreas.
> Shawn
> soatley wrote:
>> I have a feeling I am running into the same issue here.  I am using
>> Revision 9492 and the problem I encounter is the Invalid Argument error
>> when adding vector layers to the map.
>> I have tried it on IE 7 (Win XP 32 bit) and IE 8 (Vista 64, in
>> compatability mode).  IE 8 on Vista not in compat. mode works fine.
>> It seems to be very similar to the issue with Ticket 1910 from what I can
>> tell....  Setting up an IE breakpoint on line 600 of OpenLayers.js it
>> breaks where the variables w and h are assigned because this.size.w is
>> NaN.  If you were to look at the VML.js file, it is in the area of line
>> 154.
>> Does anyone have any new information or a way I can work around this?
>> Shawn
>> Christopher Schmidt-2 wrote:
>>> On Thu, Jun 18, 2009 at 10:23:15AM -0700, palewire wrote:
>>>> I've encountered some IE8 errors too. Here's the paste from what the
>>>> browser
>>>> gives you. Is there anything I can do to help out?
>>> What SVN version is this with? This should only have been fixed in the
>>> last few commits.
>>> -- Chris
>>>> Webpage error details
>>>> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1;
>>>> Trident/4.0)
>>>> Timestamp: Thu, 18 Jun 2009 17:21:04 UTC
>>>> Message: Invalid argument.
>>>> Line: 793
>>>> Char: 110
>>>> Code: 0
>>>> URI: http:// ... /openlayers/OpenLayers.js
>>>> Asle Benoni wrote:
>>>>> Sorry Christopher and others. That was a bad one from me. I did't like
>>>>> my attitude there.
>>>>> Of course I will test it since I had the problem just now. Glad you
>>>>> pointed that out since I am always so glad and amazed at people here
>>>>> just helping out ;-)
>>>>> Hope I can contribute also.
>>>>> /asle
>>>>> Den 12. juni. 2009 kl. 16.01 skrev Christopher Schmidt:
>>>>>> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
>>>>>>> Thanks Kenneth, the compatibility hack works fine. I would rather
>>>>>>> not hack
>>>>>>> VML.js but I see this hack is newer than the one I tried. As long
>>>>>>> as the
>>>>>>> quickfix works I am satisfied. But would like to know if some have
>>>>>>> success
>>>>>>> with it and if it is included in future OL release.
>>>>>> It can't be included in a future OL release until people test it. If
>>>>>> you're unwilling to test it, the chances it will be included
>>>> decrease.
>>>>>> Please help test it if you care about it.
>>>>>> -- Chris
>>>>>>> /asle
>>>>>>> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
>>>>>>>> Hi,
>>>>>>>> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
>>>>>>>> A/S<ks at geograf.dk> wrote:
>>>>>>>>> Note sure what the actual problem is, but there are notes that
>>>>>>>>> the patch
>>>>>>>>> does not solve all issues.
>>>>>>>>> There is a nother fix mentioned, namely the one in comment #20:
>>>>>>>>> http://trac.openlayers.org/ticket/1910#comment:20
>>>>>>>>> This effectively places IE8 in IE7 compatibility mode, and it
>>>>>>>>> works.
>>>>>>>>> Although it's not the correct long term solution, you can use it
>>>>>>>>> until
>>>>>>>>> the issue is fixed more permanently.
>>>>>>>> The latest patch [1] should fix all vector layer issues in IE8. It
>>>>>>>> would be nice to get some feedback if this is really the case.
>>>>>>>> Regards,
>>>>>>>> Andreas.
>>>>>>>> [1]
>>>> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
>>>>>>>> Andreas Hocevar
>>>>>>>> OpenGeo - http://opengeo.org/
>>>>>>>> Expert service straight from the developers.
>>>>>>> _______________________________________________
>>>>>>> Users mailing list
>>>>>>> Users at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>>> Christopher Schmidt
>>>>>> MetaCarta
>>>>> Users mailing list
>>>> View this message in context:
>>>> http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3114656.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> Users mailing list
>>> Christopher Schmidt
>>> MetaCarta
>>> Users mailing list
Andreas Hocevar
