[OpenLayers-Users] Error displaying map in IE8 - VML.js
soatley
shawn at niagarafalls.ca
Wed Jul 29 12:28:53 EDT 2009
Should have checked my CSS before posting that mesage.....
Here is what I already have defined in for my map object:
#map
position: absolute;
width: 100%;
height: 100%;
top: 0px;
left: 0px;
Andreas Hocevar-2 wrote:
> soatley wrote:
>> In case anyone else runs into this, I found out that after the map is
>> created, it sometimes doesn't set a height or width value in the map.size
>> property. Here's my fix which seems to work quite nicely:
>> map = new OpenLayers.Map('map', options);
>> if (isNaN(map.size.w) || isNaN(map.size.h)) {
>> map.updateSize();
> You can also make sure that the container where you render the map in
> (in your snippet a div or whatever element with id 'map') has a width
> and height style before you create the map object.
> Regards,
> Andreas.
>> Shawn
>> soatley wrote:
>>> I have a feeling I am running into the same issue here. I am using
>>> Revision 9492 and the problem I encounter is the Invalid Argument error
>>> when adding vector layers to the map.
>>> I have tried it on IE 7 (Win XP 32 bit) and IE 8 (Vista 64, in
>>> compatability mode). IE 8 on Vista not in compat. mode works fine.
>>> It seems to be very similar to the issue with Ticket 1910 from what I
>>> can
>>> tell.... Setting up an IE breakpoint on line 600 of OpenLayers.js it
>>> breaks where the variables w and h are assigned because this.size.w is
>>> NaN. If you were to look at the VML.js file, it is in the area of line
>>> 154.
>>> Does anyone have any new information or a way I can work around this?
>>> Shawn
>>> Christopher Schmidt-2 wrote:
>>>> On Thu, Jun 18, 2009 at 10:23:15AM -0700, palewire wrote:
>>>>> I've encountered some IE8 errors too. Here's the paste from what the
>>>>> browser
>>>>> gives you. Is there anything I can do to help out?
>>>> What SVN version is this with? This should only have been fixed in the
>>>> last few commits.
>>>> -- Chris
>>>>> Webpage error details
>>>>> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1;
>>>>> Trident/4.0)
>>>>> Timestamp: Thu, 18 Jun 2009 17:21:04 UTC
>>>>> Message: Invalid argument.
>>>>> Line: 793
>>>>> Char: 110
>>>>> Code: 0
>>>>> URI: http:// ... /openlayers/OpenLayers.js
>>>>> Asle Benoni wrote:
>>>>>> Sorry Christopher and others. That was a bad one from me. I did't
>>>>>> like
>>>>>> my attitude there.
>>>>>> Of course I will test it since I had the problem just now. Glad you
>>>>>> pointed that out since I am always so glad and amazed at people here
>>>>>> just helping out ;-)
>>>>>> Hope I can contribute also.
>>>>>> /asle
>>>>>> Den 12. juni. 2009 kl. 16.01 skrev Christopher Schmidt:
>>>>>>> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
>>>>>>>> Thanks Kenneth, the compatibility hack works fine. I would rather
>>>>>>>> not hack
>>>>>>>> VML.js but I see this hack is newer than the one I tried. As long
>>>>>>>> as the
>>>>>>>> quickfix works I am satisfied. But would like to know if some have
>>>>>>>> success
>>>>>>>> with it and if it is included in future OL release.
>>>>>>> It can't be included in a future OL release until people test it. If
>>>>>>> you're unwilling to test it, the chances it will be included
>>>>> decrease.
>>>>>>> Please help test it if you care about it.
>>>>>>> -- Chris
>>>>>>>> /asle
>>>>>>>> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
>>>>>>>>> Hi,
>>>>>>>>> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
>>>>>>>>> A/S<ks at geograf.dk> wrote:
>>>>>>>>>> Note sure what the actual problem is, but there are notes that
>>>>>>>>>> the patch
>>>>>>>>>> does not solve all issues.
>>>>>>>>>> There is a nother fix mentioned, namely the one in comment #20:
>>>>>>>>>> http://trac.openlayers.org/ticket/1910#comment:20
>>>>>>>>>> This effectively places IE8 in IE7 compatibility mode, and it
>>>>>>>>>> works.
>>>>>>>>>> Although it's not the correct long term solution, you can use it
>>>>>>>>>> until
>>>>>>>>>> the issue is fixed more permanently.
>>>>>>>>> The latest patch [1] should fix all vector layer issues in IE8. It
>>>>>>>>> would be nice to get some feedback if this is really the case.
>>>>>>>>> Regards,
>>>>>>>>> Andreas.
>>>>>>>>> [1]
>>>>> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
>>>>>>>>> Andreas Hocevar
>>>>>>>>> OpenGeo - http://opengeo.org/
>>>>>>>>> Expert service straight from the developers.
>>>>>>>> _______________________________________________
>>>>>>>> Users mailing list
>>>>>>>> Users at openlayers.org
>>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>>>> Christopher Schmidt
>>>>>>> MetaCarta
>>>>>> Users mailing list
>>>>> View this message in context:
>>>>> http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3114656.html
>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>> Users mailing list
>>>> Christopher Schmidt
>>>> MetaCarta
>>>> Users mailing list
> Andreas Hocevar
> Users mailing list
View this message in context: http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3350935.html
