[OpenLayers-Users] Restore feature's geometry
Alexandre Dube
adube at mapgears.com
Wed Jul 29 14:09:50 EDT 2009
Well, in the end I would really like to avoid the use of
layer.refresh({'force':true}) if possible.
If you activate the DrawFeature control while modifying a feature
(instead of hitting cancel), the geometry of the current modified
feature still needs to be restored (didn't hit the "save" button). So
the following happens :
1. layer.refresh is called
2. DrawFeature control activates (at the same time, "featureadded"
events are registered")
3. response from the layer.refresh draws new features, but they get
all engulfed in the DrawFeature "featureadded" events (resulting in
selecting them all in my case)
So, I would really need an other option... Any clue ?
I'll show the "weird" behavior of cloning the geometry in a live
example. Maybe I'm doing something wrong.
Alexandre
Alexandre Dube wrote:
> Hi,
> I'd like to know if there's a better (faster) way to restore a
> modified feature's geometry other than using layer.refresh({'force':true});
> I use a ModifyFeature control with a popup that as save and cancel
> buttons. On save, it commits the changes (fine). On cancel, it should
> 'restore' the feature to its original state (at least the geometry).
> I tried to clone the feature + fid before modifications, then on
> cancel destroy the original feature and add the clone but it's obviously
> wrong to do so since it becomes unbound to its source.
> I also tried to clone the geometry only but I had weird behaviors
> (duplicated features).
> Any hint ?
Alexandre Dubé
Mapgears
www.mapgears.com
