[OpenLayers-Users] ZoomBox Pan in two Mapdivs at the same time
Rahn Hanno (rahn)
rahn at zhaw.ch
Thu Jul 30 07:23:02 EDT 2009
Hello list,
I have a problem with the zoomBox.
In my Project I have two different map windows. The maps show the same but in different times. The Geometries are polygons.
Now I try to realise a rectangle zoom with a button. For this I use the NavToolbar Control.
This works fine for the first window. But now I will use it for the second window in the same time. If I zoom into the first map, then the second map should zoom in to the same center, zoomlevel, usw..
The Pan should work for both maps, too.
I will only use one button for both maps.
Perhaps somebody can help me. Sorry for my bad english and a lot of thanks for your help.
Greetings
Hanno Rahn
Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
Fachstelle Geoinformatik
Grüental, Postfach CH-8820 Wädenswil
Tel +41 (0)58 934 5592
Fax +41 (0)58 934 5580
hanno.rahn at zhaw.ch
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090730/07fd8288/attachment.html
