[OpenLayers-Users] World Wind tiles of GeoCover 2000 - not success
fmatz fmatz at nexgo.de
Fri Jul 31 09:06:34 EDT 2009
Hello,
I am trying to show the World Wind GeoCover 2000 tiles in OpenLayers.
I am using the following config:
 <LevelZeroTileSizeDegrees>2.25</LevelZeroTileSizeDegrees>
  <NumberLevels>6</NumberLevels>
  <TextureSizePixels>512</TextureSizePixels>
  <ImageFileExtension>jpg</ImageFileExtension>
- <ImageTileService>
  <ServerUrl>http://worldwind25.arc.nasa.gov/tile/tile.aspx</ServerUrl>
  <DataSetName>geocover2000</DataSetName>
of  GeoCover 2000 from
http://worldwind25.arc.nasa.gov/layerConfig/earthimages.xml
You can see the tiles e.g.
http://worldwind25.arc.nasa.gov/tile/tile.aspx?T=geocover2000&L=2&X=358&Y=246
I understand the World Wind maxResolution on Level zero : 36 degree
http://issues.worldwind.arc.nasa.gov/confluence/download/attachments/394/world+wind+tile+systemt.gif
The resolution is unit per pixels => Resolution (level zero) := 36 / 512 =
0.0703125 this is
equivalent to LZTD (level zero tiles degree) = 2.25  ?
So I am trying with following snippet:
   <script type="text/javascript">
        var map;
        function init(){
            var mapOptions = { maxResolution: 0.0703125, numZoomLevels: 21};
            map = new OpenLayers.Map('map', mapOptions);
            var ww = new OpenLayers.Layer.WorldWind( "GeoCover 2000",
                "http://worldwind25.arc.nasa.gov/tile/tile.aspx?", 2.25, 6,
                {T:"geocover2000"}, { tileSize: new OpenLayers.Size(512,512)
            map.addLayers([ww]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.setCenter(new OpenLayers.LonLat(-71.446875, 41.73515625),
15);
    </script>
but wihout success, the tile result is ../img/blank.gif .
I am afraid that I don't understand the usage of World Wind in OpenLayers.
Regards
Friedhold
View this message in context: http://n2.nabble.com/World-Wind-tiles-of-GeoCover-2000---not-success-tp3362489p3362489.html
