[OpenLayers-Users] About WFS and Openlayers
Guillaume Sueur
no-reply at neogeo-online.net
Thu Jun 4 05:36:55 EDT 2009
That can come from the size (number of vertices) of your polygons. Even
if they are only 70, if each of them counts more than 100 vertices, it's
already at least 7000 points that the browser has to deal with, which is
far too many. Consider using ST_simplify(geom,value) on your postgis
table, increasing <value> until it can be displayed. Either, use WMS layer.
Regards,
Guillaume
Manuel Albela Miranda a écrit :
> Hi everybody!
> I'm working on a GIS system with Openlayers, postgis and mapserver (all
> of them are the last version as of today) runing on a Debian SID
> environment, and i'm having problems when trying to load a wfs layer
> created with the information of a postgis table. The thing is that when
> I try to add the layer to the map in openlayers, the web browser (either
> firefox 3 or ie7) gets an exception. The layer is a multipolygon one
> representing Uganda with, more or less, 70 polygons. The script gets
> stuck when adding the layer to the map (map.AddLayer(mylayer);). I've
> been researching the whole process and the bottle neck is not the
> database and neither the creation of the wfs layer, so it seems like
> it's the way i'm trying to add the layer to the map.
> I don't know if anyone has or has had the same problem,
> Thank you very much in advance for your help.
> Manu.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
