[OpenLayers-Users] Popup can not be closed when zooming
Alexandre Dube
adube at mapgears.com
Mon Jun 8 08:16:42 EDT 2009
"this" in your checkPopup function is equal to you map object and it
has no popup property but has a popups array.
Do you use firebug ? If not, you should give it a try.
Alexandre
Asle Benoni wrote:
> Hi,
> I did not understand this as I cannot find "Moveend" as a defined
> event. Or maybe I am missing something.
> I have the following function under to define the popup box. I tried
> to write the checkPopup function without success:
> // popup box
> selectControl = new
> OpenLayers.Control.SelectFeature(map.layers[5],{onSelect:
> onFeatureSelect, onUnselect: onFeatureUnselect});
> map.addControl(selectControl);
> selectControl.activate();
> function onPopupClose(evt) {
> selectControl.unselect(selectedFeature);
> function onFeatureSelect(feature) {
> selectedFeature = feature;
> popup = new OpenLayers.Popup.FramedCloud("chicken",
> feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(100,200),
> "<h2>" +feature.attributes.gardsnavn +
> "</h2>Type: "+ feature.attributes.art +
> "<br />Kommune: "+ feature.attributes.komm +
> "<br />Beskrivelse<br /><a href='" +
> feature.attributes.urltilpdfark +
> "' target=blank><img
> src='http://naturkart.no:8080/geoserver/images/logo.png' border='0'
> alt='naturkart'></a>", null, true, onPopupClose);
> feature.popup = popup;
> map.addPopup(popup);
> function onFeatureUnselect(feature) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> feature.popup = null;
> function checkPopup(feature) {
> if (feature.popup!= null){
> map.events.register("moveend", map, checkPopup);
> /asle
> 2009/6/4 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
> Hi,
> Register a "moveend" event to your map objet :
> yourMapObj.events.register("moveend", yourMapObj, checkPopup)
> Then, in your checkPopup function, check your map if it has any
> popup and destroy them.
> Regards,
> Alexandre
> Asle Benoni wrote:
> Hello,
> I have some popups from a WFS layer and a KML layer . When I
> click the point the popup shows. If I zoom in or out without
> closing the popup the popup stays and I cannot close it. Is
> there a way to automatically close any popups that are open
> when zooming in or out?
> Thanks for any help!
> /asle
> Users mailing list
> Users at openlayers.org <mailto:Users at openlayers.org>
> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
