[OpenLayers-Users] Popup can not be closed when zooming
Asle Benoni
asle.benoni at gmail.com
Mon Jun 8 17:26:33 EDT 2009
Ok. Not really sure where to put this, when does it fire?
function checkPopup(feature) {
if (*feature.popup[]*= null){
feature.popup.destroy();
map.events.register("moveend", map, checkPopup);
I have FireBug but do not really know what to check :-(
Forgive my small knowledge here.
/asle
2009/6/8 Alexandre Dube <adube at mapgears.com>
> Hi,
> "this" in your checkPopup function is equal to you map object and it has
> no popup property but has a popups array.
> Do you use firebug ? If not, you should give it a try.
> Alexandre
> Asle Benoni wrote:
>> Hi,
>> I did not understand this as I cannot find "Moveend" as a defined event.
>> Or maybe I am missing something.
>> I have the following function under to define the popup box. I tried to
>> write the checkPopup function without success:
>> // popup box
>> selectControl = new
>> OpenLayers.Control.SelectFeature(map.layers[5],{onSelect: onFeatureSelect,
>> onUnselect: onFeatureUnselect});
>> map.addControl(selectControl);
>> selectControl.activate();
>> function onPopupClose(evt) {
>> selectControl.unselect(selectedFeature);
>> function onFeatureSelect(feature) {
>> selectedFeature = feature;
>> popup = new OpenLayers.Popup.FramedCloud("chicken",
>> feature.geometry.getBounds().getCenterLonLat(),
>> new OpenLayers.Size(100,200),
>> "<h2>" +feature.attributes.gardsnavn +
>> "</h2>Type: "+ feature.attributes.art +
>> "<br />Kommune: "+ feature.attributes.komm +
>> "<br />Beskrivelse<br /><a href='" +
>> feature.attributes.urltilpdfark +
>> "' target=blank><img src='
>> http://naturkart.no:8080/geoserver/images/logo.png' border='0'
>> alt='naturkart'></a>", null, true, onPopupClose);
>> feature.popup = popup;
>> map.addPopup(popup);
>> function onFeatureUnselect(feature) {
>> map.removePopup(feature.popup);
>> feature.popup = null;
>> } function checkPopup(feature) {
>> if (feature.popup!= null){
>> /asle
>> 2009/6/4 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
>> Hi,
>> Register a "moveend" event to your map objet :
>> yourMapObj.events.register("moveend", yourMapObj, checkPopup)
>> Then, in your checkPopup function, check your map if it has any
>> popup and destroy them.
>> Regards,
>> Alexandre
>> Asle Benoni wrote:
>> Hello,
>> I have some popups from a WFS layer and a KML layer . When I
>> click the point the popup shows. If I zoom in or out without
>> closing the popup the popup stays and I cannot close it. Is
>> there a way to automatically close any popups that are open
>> when zooming in or out?
>> Thanks for any help!
>> /asle
>> Users mailing list
>> Users at openlayers.org <mailto:Users at openlayers.org>
>> http://openlayers.org/mailman/listinfo/users
>> -- Alexandre Dubé
>> Mapgears
>> www.mapgears.com <http://www.mapgears.com>
>> Users mailing list
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090608/e544972b/attachment.html
