[OpenLayers-Users] Example of creating a POI with attributes
Alexandre Dube
adube at mapgears.com
Mon Jun 8 09:58:57 EDT 2009
Hi Mike,
Thanks for sharing. I tried it a little but couldn't make it work
unfortunately. I'm pretty sure this is not a big deal, maybe something
to do with this :
params: {
typename: layer.params.typename,
service: layer.params.service,
version: layer.params.version,
request: "DescribeFeatureType"
Sometimes, params values are in caps. Didn't try, but maybe layerParams
= OpenLayers.Util.upperCaseObject(layers.params) then use it with upper
cases parameters could do the trick.
Anyway, thanks again and keep up the good work.
Alexandre
Mike Adair wrote:
> I've added an example of using the WFS DescribeFeatureType response to
> create a form in my sandbox at:
> http://svn.openlayers.org/sandbox/madair/examples/edit-feature-attributes.html
> It will require either the proxy to be set up or a local instance of
> geoserver for the example to work.
> I haven't hooked the layer up to a save strategy yet, nor do I have a
> DrawFeature control in there but it should show the main idea.
> Mike
> Roald de Wit wrote:
>> Hi Mike,
>> If you could make this control availabe somehow, that would be great!
>> It might be a nice candidate for an addin [1].
>> Cheers, Roald
>> [1] http://trac.openlayers.org/wiki/Addins
>> Mike Adair wrote:
>>> I did a EditFeatureAttributes control a few months ago that first did
>>> a WFS DescribeFeatureType query to determine the attributes for a
>>> feature type and then created a form with inputs for each attribute.
>>> It registered with featureAdded and featureSelected events on the WFS
>>> layer to open and populate the form. Clicking on a 'save' button
>>> then triggered a Save strategy to do a WFS transaction to the DB. I
>>> seem to recall that it needed some extra information about attribute
>>> types, primary keys, etc. but it was mostly driven from the
>>> DescribeFeatureType response.
>>> I don't think there is an example online anywhere yet but I could
>>> probably put the code somewhere if you were interested.
>>> Mike Adair
>>> Stephen Woodbridge wrote:
>>>> Hi all,
>>>> Does anyone have a public page/example that demonstrates creating a
>>>> point feature and adding text attributes to it? This seems like it
>>>> would be a common use case.
>>>> Creating the vector feature is straight forward. It would be nice if
>>>> after you create the point, that you could click it and open a
>>>> balloon with fields that you could fill in and a save|cancel button
>>>> that would save it back to the server.
>>>> Maybe this is two operations:
>>>> 1) create or drag the marker for editing the location
>>>> 2) click to edit attributes or to delete marker
>>>> Mostly unsure on the attributes and the best way to glue all this
>>>> together.
>>>> Suggestions and examples would be helpful.
>>>> Thanks,
>>>> -Steve
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
