[OpenLayers-Users] Example of creating a POI with attributes
Alexandre Dube
adube at mapgears.com
Mon Jun 8 10:01:01 EDT 2009
Alexandre Dube wrote:
> Hi Mike,
> Thanks for sharing. I tried it a little but couldn't make it work
> unfortunately. I'm pretty sure this is not a big deal, maybe something
> to do with this :
> params: {
> typename: layer.params.typename,
> service: layer.params.service,
> version: layer.params.version,
> request: "DescribeFeatureType"
> Sometimes, params values
I meant properties
> are in caps. Didn't try, but maybe layerParams
> = OpenLayers.Util.upperCaseObject(layers.params) then use it with upper
> cases parameters could do the trick.
> Anyway, thanks again and keep up the good work.
> Alexandre
> Mike Adair wrote:
>> I've added an example of using the WFS DescribeFeatureType response to
>> create a form in my sandbox at:
>> http://svn.openlayers.org/sandbox/madair/examples/edit-feature-attributes.html
>> It will require either the proxy to be set up or a local instance of
>> geoserver for the example to work.
>> I haven't hooked the layer up to a save strategy yet, nor do I have a
>> DrawFeature control in there but it should show the main idea.
>> Mike
>> Roald de Wit wrote:
>>> Hi Mike,
>>> If you could make this control availabe somehow, that would be great!
>>> It might be a nice candidate for an addin [1].
>>> Cheers, Roald
>>> [1] http://trac.openlayers.org/wiki/Addins
>>> Mike Adair wrote:
>>>> I did a EditFeatureAttributes control a few months ago that first did
>>>> a WFS DescribeFeatureType query to determine the attributes for a
>>>> feature type and then created a form with inputs for each attribute.
>>>> It registered with featureAdded and featureSelected events on the WFS
>>>> layer to open and populate the form. Clicking on a 'save' button
>>>> then triggered a Save strategy to do a WFS transaction to the DB. I
>>>> seem to recall that it needed some extra information about attribute
>>>> types, primary keys, etc. but it was mostly driven from the
>>>> DescribeFeatureType response.
>>>> I don't think there is an example online anywhere yet but I could
>>>> probably put the code somewhere if you were interested.
>>>> Mike Adair
>>>> Stephen Woodbridge wrote:
>>>>> Hi all,
>>>>> Does anyone have a public page/example that demonstrates creating a
>>>>> point feature and adding text attributes to it? This seems like it
>>>>> would be a common use case.
>>>>> Creating the vector feature is straight forward. It would be nice if
>>>>> after you create the point, that you could click it and open a
>>>>> balloon with fields that you could fill in and a save|cancel button
>>>>> that would save it back to the server.
>>>>> Maybe this is two operations:
>>>>> 1) create or drag the marker for editing the location
>>>>> 2) click to edit attributes or to delete marker
>>>>> Mostly unsure on the attributes and the best way to glue all this
>>>>> together.
>>>>> Suggestions and examples would be helpful.
>>>>> Thanks,
>>>>> -Steve
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
