[OpenLayers-Users] Example of creating a POI with attributes
Mike Adair madair at dmsolutions.ca
Mon Jun 8 10:42:25 EDT 2009
Alexandre,
Yes you are correct that the WFS layer uses upper case for the params
properties so this should pick them up:
          params: {
            typename: layer.params.typename,
            service: layer.params.SERVICE,
            version: layer.params.VERSION,
            request: "DescribeFeatureType"
I think the WFS spec says those should be case insensitive in the
request however (in my case it works with my local geoserver).
Mike
Alexandre Dube wrote:
> Hi Mike,
> Thanks for sharing. I tried it a little but couldn't make it work
> unfortunately. I'm pretty sure this is not a big deal, maybe something
> to do with this :
> params: {
> service: layer.params.service,
> version: layer.params.version,
> Sometimes, params values are in caps. Didn't try, but maybe
> layerParams = OpenLayers.Util.upperCaseObject(layers.params) then use
> it with upper cases parameters could do the trick.
> Anyway, thanks again and keep up the good work.
> Alexandre
> Mike Adair wrote:
>> I've added an example of using the WFS DescribeFeatureType response
>> to create a form in my sandbox at:
>> http://svn.openlayers.org/sandbox/madair/examples/edit-feature-attributes.html
>> It will require either the proxy to be set up or a local instance of
>> geoserver for the example to work.
>> I haven't hooked the layer up to a save strategy yet, nor do I have a
>> DrawFeature control in there but it should show the main idea.
>> Mike
>> Roald de Wit wrote:
>>> Hi Mike,
>>> If you could make this control availabe somehow, that would be
>>> great! It might be a nice candidate for an addin [1].
>>> Cheers, Roald
>>> [1] http://trac.openlayers.org/wiki/Addins
>>> Mike Adair wrote:
>>>> I did a EditFeatureAttributes control a few months ago that first
>>>> did a WFS DescribeFeatureType query to determine the attributes for
>>>> a feature type and then created a form with inputs for each
>>>> attribute.  It registered with featureAdded and featureSelected
>>>> events on the WFS layer to open and populate the form.  Clicking on
>>>> a 'save' button then triggered a Save strategy to do a WFS
>>>> transaction to the DB.  I seem to recall that it needed some extra
>>>> information about attribute types, primary keys, etc. but it was
>>>> mostly driven from the DescribeFeatureType response.
>>>> I don't think there is an example online anywhere yet but I could
>>>> probably put the code somewhere if you were interested.
>>>> Mike Adair
>>>> Stephen Woodbridge wrote:
>>>>> Hi all,
>>>>> Does anyone have a public page/example that demonstrates creating
>>>>> a point feature and adding text attributes to it? This seems like
>>>>> it would be a common use case.
>>>>> Creating the vector feature is straight forward. It would be nice
>>>>> if after you create the point, that you could click it and open a
>>>>> balloon with fields that you could fill in and a save|cancel
>>>>> button that would save it back to the server.
>>>>> Maybe this is two operations:
>>>>> 1) create or drag the marker for editing the location
>>>>> 2) click to edit attributes or to delete marker
>>>>> Mostly unsure on the attributes and the best way to glue all this
>>>>> together.
>>>>> Suggestions and examples would be helpful.
>>>>> Thanks,
>>>>>    -Steve
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
