[OpenLayers-Users] Popup can not be closed when zooming
Asle Benoni
asle.benoni at gmail.com
Thu Jun 11 06:40:36 EDT 2009
Thanks!
I am not sure if I wrote this correctly. If you can take a quick look at
http://naturkart.no/kulturminnekart/ and turn on som layers, click a marker
and then zoom. The popup stays put. I was not sure what to use instead ofr
"wfslayer".
/asle
2009/6/11 Ivan Grcic <igrcic at gmail.com>
> Hi Asle, this migh help also, especiall if you are using some strategy
> like BBOX with wfs layer:
> wfsLayer.events.register('loadstart', this, function (evt){
> if(selectedFeature && selectedFeature.popup){
> selectControls.unselect(PARAMS.selectedFeature);
> //selectControls.unselectAll(); <= this might also work
> i was banging my head with this one for some time, then i figured out
> that features are NOT being unselected before they are removed from
> the layer (BBOX has changed => new features are fetched)
> that way the popup stays on map but that feature that the popup has
> been opened on doesnt exist anymore, and there was no way to close the
> popup.
> registering loadstart event and unselecting feature there before the
> strategy loads new features did the job!
> hope it helps someone,
> cheers
> On Tue, Jun 9, 2009 at 2:15 PM, Alexandre Dube<adube at mapgears.com> wrote:
> > Hi,
> > Just put a break point on this line :
> > if (*feature.popup[]*= null){
> > Then, using the "script" tag and at the right the "watch" tab, you will
> > then be able to see all variables and object currently available,
> > including "this" (which should be your map object).
> > There's plenty of tutorials on the web that could help. Just google
> > "firebug how to use" for example.
> > Best of luck,
> > Alexandre
> > Asle Benoni wrote:
> >> Ok. Not really sure where to put this, when does it fire?
> >> function checkPopup(feature) {
> >> feature.popup.destroy();
> >> map.events.register("moveend", map, checkPopup);
> >> I have FireBug but do not really know what to check :-(
> >> Forgive my small knowledge here.
> >> /asle
> > Alexandre Dubé
> > Mapgears
> > www.mapgears.com
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090611/74f85b38/attachment.html
