[OpenLayers-Users] Popup can not be closed when zooming
Ivan Grcic
igrcic at gmail.com
Thu Jun 11 10:50:01 EDT 2009
voila:
var map = toolbarExample.app.vector.map; // MAN you really hid your
map object well :P
var bygningLayer = map.getLayersByName('Bygning')[0];
bygningLayer.events.register('loadstart', this, function (evt){
if(selectedFeature && selectedFeature.popup){
map.removePopup(selectedFeature.popup);
selectedFeature.popup.destroy();
selectedFeature.popup = null;
selectedFeature = null;
//selectControl.unselectAll(); // you are not closing your
popup on featureUnselect so this wont work for you...
BTW you HAVE to use some of the loading strategies, i suggest bbox at least.
cheers
On Thu, Jun 11, 2009 at 12:40 PM, Asle Benoni<asle.benoni at gmail.com> wrote:
> Thanks!
> I am not sure if I wrote this correctly. If you can take a quick look at
> http://naturkart.no/kulturminnekart/ and turn on som layers, click a marker
> and then zoom. The popup stays put. I was not sure what to use instead ofr
> "wfslayer".
> /asle
> 2009/6/11 Ivan Grcic <igrcic at gmail.com>
>> Hi Asle, this migh help also, especiall if you are using some strategy
>> like BBOX with wfs layer:
>> wfsLayer.events.register('loadstart', this, function (evt){
>> selectControls.unselect(PARAMS.selectedFeature);
>> //selectControls.unselectAll(); <= this might also work
>> i was banging my head with this one for some time, then i figured out
>> that features are NOT being unselected before they are removed from
>> the layer (BBOX has changed => new features are fetched)
>> that way the popup stays on map but that feature that the popup has
>> been opened on doesnt exist anymore, and there was no way to close the
>> popup.
>> registering loadstart event and unselecting feature there before the
>> strategy loads new features did the job!
>> hope it helps someone,
>> cheers
>> On Tue, Jun 9, 2009 at 2:15 PM, Alexandre Dube<adube at mapgears.com> wrote:
>> > Hi,
>> > Just put a break point on this line :
>> > if (*feature.popup[]*= null){
>> > Then, using the "script" tag and at the right the "watch" tab, you will
>> > then be able to see all variables and object currently available,
>> > including "this" (which should be your map object).
>> > There's plenty of tutorials on the web that could help. Just google
>> > "firebug how to use" for example.
>> > Best of luck,
>> > Alexandre
>> > Asle Benoni wrote:
>> >> Ok. Not really sure where to put this, when does it fire?
>> >> function checkPopup(feature) {
>> >> feature.popup.destroy();
>> >> map.events.register("moveend", map, checkPopup);
>> >> I have FireBug but do not really know what to check :-(
>> >> Forgive my small knowledge here.
>> >> /asle
>> > Alexandre Dubé
>> > Mapgears
>> > www.mapgears.com
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> Ivan Grcic
Ivan Grcic
