[OpenLayers-Users] dynamic WMS add/remove problem
Andreas Hocevar ahocevar at opengeo.org
Tue Jun 16 11:37:34 EDT 2009
Balázs Bámer wrote:
> Hi Andreas,
>> no need to remove, destroy and re-add the layer. If your WMS URL stays
>> the same, all you need to do is
> I need to do this because the URL changes. Here the ***** value
> changes, the 'shapefile.map' part changes when someone wants to upload
> a new shapefile.
> var shapefile_wms = new OpenLayers.Layer.WMS("shapefile [name from PHP var]",
> "http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.1/mapserv",
>    layers: 'shapefile',
> ******   map: '/var/lib/mapserver-5.4.1/blokknez/shapefile/shapefile.map',
>    transparent: "true"
In that case, you also do not need to destroy and re-add the layer.
Instead of
layer.reload(true);
layer.mergeNewParams({map: '/your/mapfile'});
The layer will reload immediately. But in the meantime, I have another
suspicion: can it be that you request the layer with the new mapfile
before the upload is processed on the server? You should do the reload
in a success callback of your upload request.
Regards,
Andreas.
>    scales:[2000000,1500000,1000000,750000,500000,300000,200000,150000,100000,75000,50000,30000,20000,15000,10000,7500,5000,3000,2000,1500,1000],
>    isBaseLayer:false,
>    visibility:true
> The constructed URL looks like
> http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.1/mapserv?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&map=/var/lib/mapserver-5.4.1/blokknez/shapefile/shapefile.map&layers=shapefile&srs=epsg:23700&BBOX=420000,40000,950000,370000&WIDTH=938&HEIGHT=591&FORMAT=image/png
> the above 'shapefile.map' part specifies which uploaded shapefile to
> display. Meanwhile I somewhat rewrote the stuff to allow several users
> use independent shapefiles and mapfiles, and it works now:
> http://att-it.homelinux.net:22080/blokknez/tobbfelhaszn.php
> Thank you, best regards: Balázs
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
