[OpenLayers-Users] click to select, highlight feature example
Nicholas Efremov-Kendall
n.e.kendall at gmail.com
Tue Jun 16 11:58:50 EDT 2009
Hi all,
another novice error probably. I'm trying to replicate the function of the
click to select, highlight selected example. I essentially copy/pasted the
example into my code, but I'm perplexed as to why I don't have the select on
click feature activated? The highlighting works fine, but nothing happens
when I click. My current set up is very close to the example, except I use a
local gml rather than the vectors from the wkt geometry.
here's my code, and I'm using the web-url for the code.
var map, controls;
function init() {
map = new OpenLayers.Map ("map",
controls:[
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.LayerSwitcher(),
new OpenLayers.Control.Attribution()],
sphericalMercator: true,
maxExtent: new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
maxResolution: 156543.0399,
numZoomLevels: 19,
units: 'm',
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
var myBaseLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0", {layers: 'basic', projection:
"myproj"} );
map.addLayer(myBaseLayer);
var topo = new OpenLayers.Layer.GML("Topography", "data/test4.gml",
projection: new OpenLayers.Projection("EPSG:4326")});
map.addLayer(topo);
// Selection and hoverstate controls
var report = function(e) {
OpenLayers.Console.log(e.type, e.feature.id);
var highlightCtrl = new OpenLayers.Control.SelectFeature(topo, {
hover: true,
highlightOnly: true,
renderIntent: "temporary",
eventListeners: {
beforefeaturehighlighted: report,
featureunhighlighted: report
var selectCtrl = new OpenLayers.Control.SelectFeature(topo,
{clickout: true}
map.addControl(highlightCtrl);
map.addControl(selectCtrl);
highlightCtrl.activate();
selectCtrl.activate();
if( ! map.getCenter() ){
topo.events.register('loadend', topo,
function(){map.zoomToExtent(topo.getDataExtent())});
map.setCenter(null, null);
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090616/886fd4ed/attachment.html
