[OpenLayers-Users] click to select, highlight feature example
Eric Lemoine eric.lemoine at camptocamp.com
Tue Jun 16 16:39:05 EDT 2009
On Tuesday, June 16, 2009, Nicholas Efremov-Kendall
<n.e.kendall at gmail.com> wrote:
> Hi all,
> another novice error probably. I'm trying to replicate the function of the click to select, highlight selected example. I essentially copy/pasted the example into my code, but I'm perplexed as to why I don't have the select on click feature activated? The highlighting works fine, but nothing happens when I click. My current set up is very close to the example, except I use a local gml rather than the vectors from the wkt geometry.
> here's my code, and I'm using the web-url for the code.
Looking at your code I have no idea what's wrong. Have you try
removing the hover (highlightOnly) control to see if the click control
then works?
> var map, controls;
> function init() {
>             map = new OpenLayers.Map ("map",
>                     controls:[
>                     new OpenLayers.Control.Navigation(),
>                     new OpenLayers.Control.PanZoomBar(),
>                     new OpenLayers.Control.LayerSwitcher(),
>                     new OpenLayers.Control.Attribution()],
>                 sphericalMercator: true,
>                 maxExtent: new OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
>                 maxResolution: 156543.0399,
>                 numZoomLevels: 19,
>                 units: 'm',
>                 projection: new OpenLayers.Projection("EPSG:900913"),
>                 displayProjection: new OpenLayers.Projection("EPSG:4326"),
>             var myBaseLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>         "http://labs.metacarta.com/wms/vmap0", {layers: 'basic', projection: "myproj"} );
>          map.addLayer(myBaseLayer);
>          var topo = new OpenLayers.Layer.GML("Topography", "data/test4.gml", {
>   projection: new OpenLayers.Projection("EPSG:4326")});
>          map.addLayer(topo);
> // Selection and hoverstate controls
>           var report = function(e) {
>                 OpenLayers.Console.log(e.type, e.feature.id);
>             var highlightCtrl = new OpenLayers.Control.SelectFeature(topo, {
>                 hover: true,
>                 highlightOnly: true,
>                 renderIntent: "temporary",
>                 eventListeners: {
>                     beforefeaturehighlighted: report,
>                     featureunhighlighted: report
>    var selectCtrl = new OpenLayers.Control.SelectFeature(topo,
>                 {clickout: true}
>             map.addControl(highlightCtrl);
>               map.addControl(selectCtrl);
>             highlightCtrl.activate();
>             selectCtrl.activate();
>             if( ! map.getCenter() ){
>             topo.events.register('loadend', topo, function(){map.zoomToExtent(topo.getDataExtent())});
>             map.setCenter(null, null);
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
