[OpenLayers-Users] WMSGetFeatureInfo Format
Arnd Wippermann
arnd.wippermann at web.de
Tue Mar 3 17:52:59 EST 2009
Hi Alexandre,
I would suggest, you have to use xml as parameter and not an xml object.
oFeatures = oFormat.read_msGMLOutput("response.xml");
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Alexandre Dube
Gesendet: Dienstag, 3. März 2009 21:21
An: OpenLayers users mailing list
Betreff: [OpenLayers-Users] WMSGetFeatureInfo Format
Hi users,
I'm having a hard time using the WMSGetFeatureInfo format.
Instead of explaining, below's snippet (1). Because I currently can't
have a response from my server since I have problems with HTTPS and proxy, I
load a xml (see attached) instead ( it's a msGMLOutput XML from MapServer ).
I get an empty features array. Any clue what I'm doing wrong ?
(1) /*---------snippet---------*/
showResult: function(response){
var oFeatures;
var oFormat = new OpenLayers.Format.WMSGetFeatureInfo();
if(!response){
var xmlDoc=document.implementation.createDocument("","",null);
xmlDoc.async="false";
xmlDoc.load("response.xml");
oFeatures = oFormat.read_msGMLOutput(xmlDoc);
} else {
oFeatures = oFormat.read_msGMLOutput(response.responseXML ||
response.responseText);
Alexandre Dubé
Mapgears
www.mapgears.com
