[OpenLayers-Users] WFS/WMS
chris Wild
chrismwild at gmail.com
Tue Mar 3 18:29:46 EST 2009
Can someone please tell me why my WFS layer is drifting off my WMS location.
Both layers are using WGS84 co-ord.
Have attached jpg of track that should display around lake.
Any help much appreciated.
Regards
Chris
<!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>OpenLayers map preview</title>
<!-- Import OL CSS, auto import does not work with our minified OL.js build
<link rel="stylesheet" type="text/css" href="
http://localhost:8080/geoserver/openlayers/theme/default/style.css"/>
<!-- Basic CSS definitions -->
<style type="text/css">
/* General settings */
body {
font-family: Verdana, Geneva, Arial, Helvetica, sans-serif;
font-size: small;
/* Toolbar styles */
#toolbar {
position: relative;
padding-bottom: 0.5em;
display: none;
#toolbar ul {
list-style: none;
padding: 0;
margin: 0;
#toolbar ul li {
float: left;
padding-right: 1em;
#toolbar ul li a {
font-weight: bold;
font-size: smaller;
vertical-align: middle;
color: black;
text-decoration: none;
#toolbar ul li a:hover {
text-decoration: underline;
#toolbar ul li * {
/* The map and the location bar */
#map {
clear: both;
position: relative;
width: 800px;
height: 371px;
border: 1px solid black;
#wrapper {
width: 800px;
#location {
float: right;
#options {
position: absolute;
left: 13px;
top: 7px;
z-index: 3000;
/* Styles used by the default GetFeatureInfo output, added to make IE happy
table.featureInfo, table.featureInfo td, table.featureInfo th {
border: 1px solid #ddd;
border-collapse: collapse;
margin: 0;
padding: 0;
font-size: 90%;
padding: .2em .1em;
padding: .2em .2em;
text-transform: uppercase;
font-weight: bold;
background: #eee;
table.featureInfo td {
background: #fff;
table.featureInfo tr.odd td {
background: #eee;
table.featureInfo caption {
text-align: left;
font-size: 100%;
font-weight: bold;
padding: .2em .2em;
</style>
<script src="http://localhost:8080/geoserver/openlayers/OpenLayers.js"
type="text/javascript">
</script>
<script defer="defer" type="text/javascript">
var map;
var untiled;
var tiled;
var pureCoverage = true;
// pink tile avoidance
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
// make OL compute scale according to WMS spec
OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
function init(){
// if this is just a coverage or a group of them, disable a few items,
// and default to jpeg format
format = 'image/png';
if(pureCoverage) {
document.getElementById('filterType').disabled = true;
document.getElementById('filter').disabled = true;
document.getElementById('antialiasSelector').disabled = true;
document.getElementById('updateFilterButton').disabled = true;
document.getElementById('resetFilterButton').disabled = true;
document.getElementById('jpeg').selected = true;
format = "image/jpeg";
var bounds = new OpenLayers.Bounds(
174.38698427874348, -39.46185934677626,
174.4352962787435, -39.43797334677626
var options = {
controls: [],
maxExtent: bounds,
maxResolution: 0.00018871875,
projection: "EPSG:4326",
units: 'degrees'
map = new OpenLayers.Map('map', options);
// setup tiled layer
tiled = new OpenLayers.Layer.WMS(
"topp:RectifyTRC_APP_wgs - Tiled", "http://localhost:8080/geoserver/wms",
layers: 'topp:RectifyTRC_APP_wgs',
styles: '',
height: '371',
width: '800',
srs: 'EPSG:4326',
format: format,
tiled: 'true',
tilesOrigin : "174.38698427874348,-39.46185934677626"
{buffer: 0}
wfs = new OpenLayers.Layer.WFS(
'topp:walkingtrkwgs', "http://localhost:8080/geoserver/wfs",
srs: 'EPSG:4326',
typename:"walkingtrkwgs",
height: '544',
styles: '',
format: format,
tiled: 'true',
tilesOrigin : "174.39553846817478,-39.46070911608958"
{buffer: 0}
// setup single tiled layer
untiled = new OpenLayers.Layer.WMS(
"topp:RectifyTRC_APP_wgs - Untiled", "http://localhost:8080/geoserver/wms",
styles: '',
height: '371',
width: '800',
srs: 'EPSG:4326',
format: format
{singleTile: true, ratio: 1}
map.addLayers([untiled, tiled, wfs]);
// build up all controls
map.addControl(new OpenLayers.Control.PanZoomBar({
position: new OpenLayers.Pixel(2, 15)
map.addControl(new OpenLayers.Control.Navigation());
map.addControl(new OpenLayers.Control.OverviewMap());
map.addControl(new OpenLayers.Control.Scale($('scale')));
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition({element:
$('location')}));
map.zoomToExtent(bounds);
// wire up the option button
var options = document.getElementById("options");
options.onclick = toggleControlPanel;
// support GetFeatureInfo
map.events.register('click', map, function (e) {
document.getElementById('nodelist').innerHTML = "Loading... please wait...";
var params = {
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: map.layers[0].params.LAYERS,
FEATURE_COUNT: 50,
Layers: 'topp:RectifyTRC_APP_wgs',
Styles: '',
Srs: 'EPSG:4326',
WIDTH: map.size.w,
HEIGHT: map.size.h,
format: format};
OpenLayers.loadURL("http://localhost:8080/geoserver/wms", params, this,
setHTML, setHTML);
OpenLayers.Event.stop(e);
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090304/703f842f/attachment.html
