[OpenLayers-Users] Sizing background images and StyleMaps
Nicholas Bergson-Shilcock
nicholasbs at openplans.org
Tue Mar 3 18:58:45 EST 2009
Excerpts from Ivan Grcic's message of Thu Feb 26 16:36:23 -0500 2009:
> ooops sorry, i didnt see you said background image size. i dont know
> if there is such an option in api now...but if u find something you
> can put it in the docs ;)
I spoke with Tim Schwab about this and it turns out the current release does
not support setting the width/height of background graphics separately. At
present, the background graphic's size is set to be the same as the foreground
graphic's.
There's a patch to allow setting the background width and height on their own
here: http://trac.openlayers.org/ticket/1968
-Nick
> cheers
> On 2/26/09, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> > externalGraphic
> > An external image to be used to represent a point.
> > graphicWidth, graphicHeight
> > These properties define the height and width of an
> > externalGraphic. This is an alternative to the pointRadius symbolizer
> > property to be used when your graphic has different sizes in the X and
> > Y direction.
> > graphicOpacity
> > Opacity of an external graphic.
> > graphicXOffset, graphicYOffset
> > Where the ‘center’ of an externalGraphic should be.
> > graphicName
> > Name of a type of symbol to be used for a point mark.
> > cheers
> > On 2/26/09, Nicholas Bergson-Shilcock <nicholasbs at openplans.org> wrote:
> >> Excerpts from Christopher Schmidt's message of Thu Feb 26 12:26:38 -0500
> >> 2009:
> >>> On Thu, Feb 26, 2009 at 12:16:05PM -0500, Nicholas Bergson-Shilcock
> >>> wrote:
> >>> > Hello,
> >>> > I'm pretty new to OpenLayers and I have a couple of questions.
> >>> > 1) How can I set the size of a background graphic? I'm doing something
> >>> > similar
> >>> > to the marker shadow example here[1]. I guessed and used
> >>> > graphicWidth/graphicHeight to set the size of my marker image (which
> >>> > works),
> >>> > but neither backgroundGraphicWidth nor backgroundWidth seem to have
> >>> > any
> >>> > effect
> >>> > on my shadow image. What's the correct way to do this?
> >>> > 2) Is there a place to look up all of the options for an
> >>> > OpenLayers.StyleMap
> >>> > object?
> >>> http://docs.openlayers.org/library/feature_styling#style-properties
> >> Ah, thanks for pointing me towards these. This is just the type of doc I
> >> was
> >> looking for, however, I don't see any options relating to background
> >> images.
> >> Do
> >> you know if it's possible to explicitly set the size of a background
> >> image?
> >> Thanks for the help and a great product,
> >> -Nick
> >>> Regards,
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Ivan Grcic
