[OpenLayers-Users] need Static image as map of small city with
correct longitude and latitude
nab
nabinrs at gmail.com
Mon Mar 9 10:28:50 EDT 2009
I had seen your posts and replies in this forum, which is impressive and
helped me lot as well while using openlayer.
Actaully i am new to openlayer and i am using static map image(jpg) of my
city but i could not get correct long/lat value since i use map of very
small city, i try to fix it through
OpenLayers.Bounds(15.865164, 58.172783, 16.651403, 58.620233) and i set the
centre long/lat as 0,0 which is not workin then i set them in to its real
long/lat that is also not working.
is there any method which i didn't understood to make static map of my city
with long/lat value.
The concept that i follow for Bounds and centre are:
-------------------------------------(long1, lat1)
| image (lon,lat) |
(long2,lat2)-------------------------------------
i would be very thankful if you could help me.
regards,
nabin
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090309/7fd132e0/attachment.html
