[OpenLayers-Users] need Static image as map of small city with
correct longitude and latitude
Pierre GIRAUD
bluecarto at gmail.com
Mon Mar 9 11:05:25 EDT 2009
Hi Nabin,
Perhaps you should have a look at the "Image" layer class.
http://dev.openlayers.org/docs/files/OpenLayers/Layer/Image-js.html
You can find an example here :
http://www.openlayers.org/dev/examples/image-layer.html
If this is still not working, please come back with some code to show
us what you already did.
Regards,
Pierre
On Mon, Mar 9, 2009 at 3:28 PM, nab <nabinrs at gmail.com> wrote:
> Hi,
> I had seen your posts and replies in this forum, which is impressive and
> helped me lot as well while using openlayer.
> Actaully i am new to openlayer and i am using static map image(jpg) of my
> city but i could not get correct long/lat value since i use map of very
> small city, i try to fix it through
> OpenLayers.Bounds(15.865164, 58.172783, 16.651403, 58.620233) and i set the
> centre long/lat as 0,0 which is not workin then i set them in to its real
> long/lat that is also not working.
> is there any method which i didn't understood to make static map of my city
> with long/lat value.
> The concept that i follow for Bounds and centre are:
> -------------------------------------(long1, lat1)
> | image (lon,lat) |
> (long2,lat2)-------------------------------------
> i would be very thankful if you could help me.
> regards,
> nabin
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Pierre GIRAUD
http://www.camptocamp.com
Sent from: Paris J France.
