[OpenLayers-Users] need Static image as map of small city with
correct longitude and latitude
nab
nabinrs at gmail.com
Mon Mar 9 11:43:02 EDT 2009
Thanks for the reply,
here is the code which i used with static map, but the longitued and
latitude i got is incorrect or sometime i couldnot even get any image loaded
on the canvas.
function init(){
map = new OpenLayers.Map('map');
var options = { numZoomLevels: 5 };
var olbound = new OpenLayers.Bounds(15.865164, 58.172783,
16.651403, 58.620233); //bounds(left,buttom,right,top)
var topograpy = new OpenLayers.Layer.Image(
'Wrap signals',
'img/image.24.png', olbound,
new OpenLayers.Size(1000, 1000),
//size in pixel of the map
options);
map.setCenter(new OpenLayers.LonLat(58.406794, 16.23069), 3);
I will be thankful, if somebody can help me with this problem.
> I had seen your posts and replies in this forum, which is impressive and
> helped me lot as well while using openlayer.
> Actaully i am new to openlayer and i am using static map image(jpg) of my
> city but i could not get correct long/lat value since i use map of very
> small city, i try to fix it through
> OpenLayers.Bounds(15.865164, 58.172783, 16.651403, 58.620233) and i set
the
> centre long/lat as 0,0 which is not workin then i set them in to its real
> long/lat that is also not working.
> is there any method which i didn't understood to make static map of my
city
> with long/lat value.
> The concept that i follow for Bounds and centre are:
> -------------------------------------(long1, lat1)
> | image (lon,lat) |
> (long2,lat2)-------------------------------------
> i would be very thankful if you could help me.
> regards,
> nabin
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090309/39f14c8f/attachment.html
