[OpenLayers-Users] need Static image as map of small city with
correct longitude and latitude
Pierre GIRAUD
bluecarto at gmail.com
Mon Mar 9 13:07:20 EDT 2009
You're not adding the layer to the map.
Try the following :
function init(){
map = new OpenLayers.Map('map');
var options = { numZoomLevels: 5 };
var olbound = new OpenLayers.Bounds(15.865164, 58.172783,
16.651403, 58.620233); //bounds(left,buttom,right,top)
var topography = new OpenLayers.Layer.Image(
'Wrap signals',
'img/image.24.png',
olbound,
new OpenLayers.Size(1000, 1000),
//size in pixel of the map
options
map.addLayer(topography);
map.zoomToMaxExtent();
map.setCenter(new OpenLayers.LonLat(16.23069, 58.406794), 3);
On Mon, Mar 9, 2009 at 4:43 PM, nab <nabinrs at gmail.com> wrote:
> Thanks for the reply,
> here is the code which i used with static map, but the longitued and
> latitude i got is incorrect or sometime i couldnot even get any image loaded
> on the canvas.
> function init(){
> var topograpy = new OpenLayers.Layer.Image(
> 'Wrap signals',
> 'img/image.24.png', olbound,
> options);
> map.setCenter(new OpenLayers.LonLat(58.406794, 16.23069), 3);
> I will be thankful, if somebody can help me with this problem.
> Hi,
>> I had seen your posts and replies in this forum, which is impressive and
>> helped me lot as well while using openlayer.
>> Actaully i am new to openlayer and i am using static map image(jpg) of my
>> city but i could not get correct long/lat value since i use map of very
>> small city, i try to fix it through
>> OpenLayers.Bounds(15.865164, 58.172783, 16.651403, 58.620233) and i set
>> the
>> centre long/lat as 0,0 which is not workin then i set them in to its real
>> long/lat that is also not working.
>> is there any method which i didn't understood to make static map of my
>> city
>> with long/lat value.
>> The concept that i follow for Bounds and centre are:
>> -------------------------------------(long1, lat1)
>> | image (lon,lat) |
>> (long2,lat2)-------------------------------------
>> i would be very thankful if you could help me.
>> regards,
>> nabin
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Pierre GIRAUD
http://www.camptocamp.com
