[OpenLayers-Users] proxyhost using window url parameters
albert valls
avalls at ngeografics.com
Mon Mar 9 13:15:27 EDT 2009
hi list,
I've found this problem... when using the proxy for the ajax queries, the
proxy adds the window url parameters to the request. Let me explain with a
sample:
window.location.url: "http://server/index.jsp?param1=value1¶m2=value2
then, when a query is retreived with a OpenLayers.ProxyHost defined, the
param1 and param2 are added. I can see something like:
http://server/proxy.jsp?url=http://otherserver/dataquery?....¶m1=value1¶m2=value2.
And taking a look at the code from Openlayers/Request.js I've found:
OpenLayers.Request = {
* Constant: DEFAULT_CONFIG
* {Object} Default configuration for all requests.
DEFAULT_CONFIG: {
method: "GET",
url: window.location.href, //<<<<<<<<<<<<<<
I'm missing something or there's no way of disabling this behaviour???
Sometimes maybe good to forward the parameters, but I think that should be
the option to disable it.
Any comment? Should I open a new ticket for this?
View this message in context: http://n2.nabble.com/proxyhost-using-window-url-parameters-tp2450321p2450321.html
