[OpenLayers-Users] proxyhost using window url parameters
albert valls
avalls at ngeografics.com
Tue Mar 10 06:44:05 EDT 2009
I've found the solution by myself.
the problem is with the OpenLayers.Ajax.Request. If you don't pass a
'parameters' option then it gets the parameters from the window url:
new OpenLayers.Ajax.Request(url,
{ method: 'post'
,onComplete: success
,onFailure: failure
,parameters: null //<<<<< solution
bye.
albert valls wrote:
> hi list,
> I've found this problem... when using the proxy for the ajax queries, the
> proxy adds the window url parameters to the request. Let me explain with a
> sample:
> window.location.url: "http://server/index.jsp?param1=value1¶m2=value2
> then, when a query is retreived with a OpenLayers.ProxyHost defined, the
> param1 and param2 are added. I can see something like:
> http://server/proxy.jsp?url=http://otherserver/dataquery?....¶m1=value1¶m2=value2.
> And taking a look at the code from Openlayers/Request.js I've found:
> OpenLayers.Request = {
> * Constant: DEFAULT_CONFIG
> * {Object} Default configuration for all requests.
> DEFAULT_CONFIG: {
> method: "GET",
> url: window.location.href, //<<<<<<<<<<<<<<
> I'm missing something or there's no way of disabling this behaviour???
> Sometimes maybe good to forward the parameters, but I think that should be
> the option to disable it.
> Any comment? Should I open a new ticket for this?
View this message in context: http://n2.nabble.com/proxyhost-using-window-url-parameters-tp2450321p2454449.html
