[OpenLayers-Users] need Static image as map of small city with
correct longitude and latitude
nab
nabinrs at gmail.com
Tue Mar 10 04:10:34 EDT 2009
Hi again,Thank to all, i Figured out my mistake,
map.zoomToMaxExtent();
I need to use it in correct order which i didn't in correct order. thank you
all once again for help and suggestions.
On Tue, Mar 10, 2009 at 8:48 AM, nab <nabinrs at gmail.com> wrote:
> Hi,I didn't sent full code before,
> Here i am sending full code:
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>OpenLayers Image Layer Example</title>
> <link rel="stylesheet" href="../theme/default/style.css"
> type="text/css" />
> <link rel="stylesheet" href="style.css" type="text/css" />
> <style type="text/css">
> p.caption {
> width: 512px;
> </style>
> <script src="../lib/OpenLayers.js"></script>
> <script type="text/javascript">
> var map;
> function init(){
> map = new OpenLayers.Map('map');
> var options = {numZoomLevels: 3};
> //var olbound = new OpenLayers.Bounds(-180, -88.759, 180,
> 88.759); //when activated displays static image
> pictures map on this but since bounds are not accurate long/lat is not
> correct
> var olbound = new OpenLayers.Bounds(15.865164,
> 58.172783,16.651403, 58.620233); //cannto display pictures plus long/lat
> also incorrect
> var graphic = new OpenLayers.Layer.Image(
> 'City Lights',
> '../img/image.24.png',
> olbound,
> new OpenLayers.Size(1000, 1000),
> options);
> map.addLayers([graphic]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MousePosition());
> map.setCenter(new OpenLayers.LonLat(16.23069, 58.406794), 3);
> </script>
> </head>
> <body onload="init()">
> <h1 id="title">Image Layer Example</h1>
> <div id="tags"></div>
> <p id="shortdesc">
> image
> </p>
> <div id="map" class="smallmap"></div>
> <div id="docs">
> <p class="caption">
> Using image which is full size as the world map can really be.
> </p>
> </div>
> </body>
> </html>
> did i missed something?
> I am trying to work on this from many days but didn't achieve success to
> display map with correct longitude and latitude value, since i need these
> values from map on click to start further calculation based on longitude nad
> latitude value.
> On Mon, Mar 9, 2009 at 10:52 PM, Pierre GIRAUD <bluecarto at gmail.com>wrote:
>> You're not adding the layer to the map.
>> Try the following :
>> function init(){
>> var options = { numZoomLevels: 5 };
>> var olbound = new OpenLayers.Bounds(15.865164, 58.172783,
>> 16.651403, 58.620233); //bounds(left,buttom,right,top)
>> var topography = new OpenLayers.Layer.Image(
>> 'Wrap signals',
>> 'img/image.24.png',
>> olbound,
>> //size in pixel of the map
>> options
>> map.addLayer(topography);
>> On Mon, Mar 9, 2009 at 4:43 PM, nab <nabinr> wrote:
>> > Thanks for the reply,
>> > here is the code which i used with static map, but the longitued and
>> > latitude i got is incorrect or sometime i couldnot even get any image
>> loaded
>> > on the canvas.
>> > function init(){
>> > var topograpy = new OpenLayers.Layer.Image(
>> > 'Wrap signals',
>> > 'img/image.24.png', olbound,
>> > options);
>> > map.setCenter(new OpenLayers.LonLat(58.406794, 16.23069), 3);
>> > I will be thankful, if somebody can help me with this problem.
>> > Hi,
>> >> I had seen your posts and replies in this forum, which is impressive
>> and
>> >> helped me lot as well while using openlayer.
>> >> Actaully i am new to openlayer and i am using static map image(jpg) of
>> my
>> >> city but i could not get correct long/lat value since i use map of very
>> >> small city, i try to fix it through
>> >> OpenLayers.Bounds(15.865164, 58.172783, 16.651403, 58.620233) and i set
>> >> the
>> >> centre long/lat as 0,0 which is not workin then i set them in to its
>> real
>> >> long/lat that is also not working.
>> >> is there any method which i didn't understood to make static map of my
>> >> city
>> >> with long/lat value.
>> >> The concept that i follow for Bounds and centre are:
>> >> -------------------------------------(long1, lat1)
>> >> | image (lon,lat) |
>> >> (long2,lat2)-------------------------------------
>> >> i would be very thankful if you could help me.
>> >> regards,
>> >> nabin
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> Pierre GIRAUD
>> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090310/5a7b00ac/attachment.html
