[OpenLayers-Users] need Static image as map of small city with
correct longitude and latitude
nab
nabinrs at gmail.com
Tue Mar 10 03:48:41 EDT 2009
Hi,I didn't sent full code before,
Here i am sending full code:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>OpenLayers Image Layer Example</title>
<link rel="stylesheet" href="../theme/default/style.css" type="text/css"
<link rel="stylesheet" href="style.css" type="text/css" />
<style type="text/css">
p.caption {
width: 512px;
</style>
<script src="../lib/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init(){
map = new OpenLayers.Map('map');
var options = {numZoomLevels: 3};
//var olbound = new OpenLayers.Bounds(-180, -88.759, 180,
88.759); //when activated displays static image
pictures map on this but since bounds are not accurate long/lat is not
correct
var olbound = new OpenLayers.Bounds(15.865164,
58.172783,16.651403, 58.620233); //cannto display pictures plus long/lat
also incorrect
var graphic = new OpenLayers.Layer.Image(
'City Lights',
'../img/image.24.png',
olbound,
new OpenLayers.Size(1000, 1000),
options);
map.addLayers([graphic]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
map.zoomToMaxExtent();
map.setCenter(new OpenLayers.LonLat(16.23069, 58.406794), 3);
</script>
</head>
<body onload="init()">
<h1 id="title">Image Layer Example</h1>
<div id="tags"></div>
<p id="shortdesc">
</p>
<div id="map" class="smallmap"></div>
<div id="docs">
<p class="caption">
Using image which is full size as the world map can really be.
</p>
</div>
</body>
</html>
did i missed something?
I am trying to work on this from many days but didn't achieve success to
display map with correct longitude and latitude value, since i need these
values from map on click to start further calculation based on longitude nad
latitude value.
On Mon, Mar 9, 2009 at 10:52 PM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> You're not adding the layer to the map.
> Try the following :
> function init(){
> var options = { numZoomLevels: 5 };
> var olbound = new OpenLayers.Bounds(15.865164, 58.172783,
> 16.651403, 58.620233); //bounds(left,buttom,right,top)
> var topography = new OpenLayers.Layer.Image(
> 'Wrap signals',
> 'img/image.24.png',
> olbound,
> //size in pixel of the map
> options
> map.addLayer(topography);
> On Mon, Mar 9, 2009 at 4:43 PM, nab <nabinr> wrote:
> > Thanks for the reply,
> > here is the code which i used with static map, but the longitued and
> > latitude i got is incorrect or sometime i couldnot even get any image
> loaded
> > on the canvas.
> > function init(){
> > var topograpy = new OpenLayers.Layer.Image(
> > 'Wrap signals',
> > 'img/image.24.png', olbound,
> > options);
> > map.setCenter(new OpenLayers.LonLat(58.406794, 16.23069), 3);
> > I will be thankful, if somebody can help me with this problem.
> > Hi,
> >> I had seen your posts and replies in this forum, which is impressive and
> >> helped me lot as well while using openlayer.
> >> Actaully i am new to openlayer and i am using static map image(jpg) of
> my
> >> city but i could not get correct long/lat value since i use map of very
> >> small city, i try to fix it through
> >> OpenLayers.Bounds(15.865164, 58.172783, 16.651403, 58.620233) and i set
> >> the
> >> centre long/lat as 0,0 which is not workin then i set them in to its
> real
> >> long/lat that is also not working.
> >> is there any method which i didn't understood to make static map of my
> >> city
> >> with long/lat value.
> >> The concept that i follow for Bounds and centre are:
> >> -------------------------------------(long1, lat1)
> >> | image (lon,lat) |
> >> (long2,lat2)-------------------------------------
> >> i would be very thankful if you could help me.
> >> regards,
> >> nabin
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Pierre GIRAUD
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090310/54d086ff/attachment.html
