[OpenLayers-Users] mapfish - openlayers - extjs - jquery usage
problems
Fabio D'Ovidio
fabiodovidio at gmail.com
Wed Mar 11 12:46:21 EDT 2009
Hello,
in order to use jquery library toghether with mapfish client i try to
summarize the problems related to:
* $ function definition in OpenLayers
* Extjs usage with jquery
OpenLayers uses part of prototype library (without include it) in the
following files:
* Util.js
* Ajax.js
* Events.js
* Calss.js
In particular in Util.js $ function is defined as following:
* Maintain $() from prototype
if ($ == null) {
var $ = OpenLayers.Util.getElement;
jQuery library also define a $ function as: $ = jQuery
Than, jQuery library is shipped with ExtJS, and MapFish ships with
ExtJS. In particular ExtJS does not load jQuery dynamically, you need to
include it in your HTML
with script tags in this order:
1. jquery.js
2. ext-jquery-adapter.js
3. ext-all.js (or your choice of files)
Now, my HTML script with script tags is as following:
viewport:null;
map:null;
// reference local blank image
Ext.BLANK_IMAGE_URL = '../../mfbase/ext/resources/images/default/s.gif';
Ext.onReady(function(){
var map = new OpenLayers.Map(*$('map')*);
this.map = map;
var wms = new OpenLayers.Layer.WMS("OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0", {layers: 'basic'},
{buffer: 0});
map.addLayers([wms]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.setCenter(new OpenLayers.LonLat(17, 2), 2);
var window = new Ext.Window({
title: 'Map',
width: 500,
height: 300,
minWidth: 300,
minHeight: 200,
layout: 'fit',
plain: true,
bodyStyle: 'padding:5px;',
items: [{
xtype: 'mapcomponent',
map: map
window.show();
and obviously I have a div in HTML template to display the map:
<div id="map"></div>
For all these reasons I must solve two problems:
1. re-name $ function in Util.js
2. include js files in the correct way to use mapfish with jQuery
So I try in this way:
1. I changed Util.js like this:
var jq = OpenLayers.Util.getElement;
and my script become:
viewport:null;
map:null;
var map = new OpenLayers.Map(*jq('map')*);
this.map = map;
'basic'}, {buffer: 0});
title: 'Map',
width: 500,
height: 300,
minWidth: 300,
minHeight: 200,
layout: 'fit',
plain: true,
items: [{
map: map
window.show();
(I tryed also using *jQuery.noConflict();* before my script
without changing Util.js file)
2. I included in my script JS files in this order:
jquery.js,\
ext-jquery-adapter.js,\
ext-all.js
and the error is:
"A[C.xtype || D] is not a constructor"
that deals with ExtJS (maybe on onReady event, I read this post:
http://extjs.com/forum/showthread.php?t=53502&highlight=onready+onload)
If I don't chage Util.js (or use *jQuery.noConflict() function*) I have
the following error:
"this.div.appendChild is not a function"
because:
1) I load up jQuery, this defines the $ function
2) I load OpenLayers, this checks if $ exists, and because it does exist,
it is not redefined in the OL (prototype) way
3) I initialize my map and send it the string 'map' as the first
argument
4) OpenLayers tries to place your map in the DOM element $('map'), but
because $() is still a jQuery function that doesn't return a DOM element,
and I get the error about appendChild not being defined!
How can I solve these problems? :-(
Please, help me if you can :-)
Thank you very much!!
Fabio D'Ovidio
Geospatial solutions
INOVA s.r.l.
Web : http://www.inovaos.it
Tel.: 081 197 57 600
mail: fabiodovidio at gmail.com
