[OpenLayers-Users] mapfish - openlayers - extjs - jquery usage
problems
Pierre GIRAUD
bluecarto at gmail.com
Thu Mar 12 11:47:43 EDT 2009
Hi Fabio,
This might be stupid but did you try the following ?
var map = new OpenLayers.Map('map');
OpenLayers.Map constructor can be given either a DOM Element or the id
of a DOM Element.
Hope this helps,
Pierre
On Wed, Mar 11, 2009 at 5:46 PM, Fabio D'Ovidio <fabiodovidio at gmail.com> wrote:
> Hello,
> in order to use jquery library toghether with mapfish client i try to
> summarize the problems related to:
> * $ function definition in OpenLayers
> * Extjs usage with jquery
> OpenLayers uses part of prototype library (without include it) in the
> following files:
> * Util.js
> * Ajax.js
> * Events.js
> * Calss.js
> In particular in Util.js $ function is defined as following:
> * Maintain $() from prototype
> if ($ == null) {
> var $ = OpenLayers.Util.getElement;
> jQuery library also define a $ function as: $ = jQuery
> Than, jQuery library is shipped with ExtJS, and MapFish ships with
> ExtJS. In particular ExtJS does not load jQuery dynamically, you need to
> include it in your HTML
> with script tags in this order:
> 1. jquery.js
> 2. ext-jquery-adapter.js
> 3. ext-all.js (or your choice of files)
> Now, my HTML script with script tags is as following:
> viewport:null;
> map:null;
> // reference local blank image
> Ext.BLANK_IMAGE_URL = '../../mfbase/ext/resources/images/default/s.gif';
> Ext.onReady(function(){
> var map = new OpenLayers.Map(*$('map')*);
> this.map = map;
> var wms = new OpenLayers.Layer.WMS("OpenLayers WMS",
> "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'},
> {buffer: 0});
> map.addLayers([wms]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.setCenter(new OpenLayers.LonLat(17, 2), 2);
> var window = new Ext.Window({
> title: 'Map',
> width: 500,
> height: 300,
> minWidth: 300,
> minHeight: 200,
> layout: 'fit',
> plain: true,
> bodyStyle: 'padding:5px;',
> items: [{
> xtype: 'mapcomponent',
> map: map
> window.show();
> and obviously I have a div in HTML template to display the map:
> <div id="map"></div>
> For all these reasons I must solve two problems:
> 1. re-name $ function in Util.js
> 2. include js files in the correct way to use mapfish with jQuery
> So I try in this way:
> 1. I changed Util.js like this:
> var jq = OpenLayers.Util.getElement;
> and my script become:
> viewport:null;
> map:null;
> var map = new OpenLayers.Map(*jq('map')*);
> this.map = map;
> 'basic'}, {buffer: 0});
> title: 'Map',
> width: 500,
> height: 300,
> minWidth: 300,
> minHeight: 200,
> layout: 'fit',
> plain: true,
> items: [{
> map: map
> window.show();
> (I tryed also using *jQuery.noConflict();* before my script
> without changing Util.js file)
> 2. I included in my script JS files in this order:
> jquery.js,\
> ext-jquery-adapter.js,\
> ext-all.js
> and the error is:
> "A[C.xtype || D] is not a constructor"
> that deals with ExtJS (maybe on onReady event, I read this post:
> http://extjs.com/forum/showthread.php?t=53502&highlight=onready+onload)
> If I don't chage Util.js (or use *jQuery.noConflict() function*) I have
> the following error:
> "this.div.appendChild is not a function"
> because:
> 1) I load up jQuery, this defines the $ function
> 2) I load OpenLayers, this checks if $ exists, and because it does exist,
> it is not redefined in the OL (prototype) way
> 3) I initialize my map and send it the string 'map' as the first
> argument
> 4) OpenLayers tries to place your map in the DOM element $('map'), but
> because $() is still a jQuery function that doesn't return a DOM element,
> and I get the error about appendChild not being defined!
> How can I solve these problems? :-(
> Please, help me if you can :-)
> Thank you very much!!
> Fabio D'Ovidio
> Geospatial solutions
> INOVA s.r.l.
> Web : http://www.inovaos.it
> Tel.: 081 197 57 600
> mail: fabiodovidio at gmail.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Pierre GIRAUD
http://www.camptocamp.com
