[OpenLayers-Users] [MapFish-Users] mapfish - openlayers - extjs - jquery usage problems
Yves Moisan yves.moisan at boreal-is.com
Fri Mar 13 08:28:08 EDT 2009
Fabio,
Thank you for taking the time to answer my question.
Cheers,
Yves
Le vendredi 13 mars 2009 à 00:40 +0100, Fabio D'Ovidio a écrit :
> Hello Yves,
> u right, using Ext toghether with jquery increase the complexity. Our
> aim is to integrate GeoReport Module of GeoBI platform [1] (that we
> are studying) into Pentaho CDF [2]. Pentaho CDF uses jQuery and
> GeoReport uses mapfish client (and also mapfish GeoJson lib). So, this
> led us to use Ext and jQuery in the same application.
> Anyway there are some limitations in using the two libraries together
> and at the moment ony Mozilla Firefox 3.0.7 is able to display in the
> correct way our first integration [3].
> We are going on with new tests on other web browsers and the
> development of a new mapFish CDF component for GeoReport.
> Thank you very much for feedback!
> [1] www.geobi.org
> [2] http://code.google.com/p/pentaho-cdf/
> [3] http://forums.pentaho.org/showthread.php?t=67960&page=2
> Fabio D'Ovidio
> 2009/3/12 Yves Moisan <yves.moisan at boreal-is.com>
>         > Hello,
>         > in order to use jquery library toghether with mapfish client
>         I read about the relative benefits of using jQuery together
>         with Ext,
>         but I wouldn't mind having your point of view as to what those
>         benefits
>         are.  The added complexity of using another JS library with an
>         already
>         pretty hefty one like Ext must be paying somehow, but I don't
>         see how.
>         Whenever you find time and if you feel like explaining, of
>         course :-)
>         Yves
