[OpenLayers-Users] FW: How to convert from meters to degrees for
CQL_FILTER DWITHIN
Kris Geusebroek
kgeusebroek at xebia.com
Fri Mar 13 10:18:15 EDT 2009
Sorry didn't reply to the list:
Hi Thomas,
I'm not using Mapserver but GeoServer so that's not an option. Also the data is used by other programs so I'm stuck with this.
The site you mention is about converting coordinates from a projection in meters to a projection in degrees (like from 28992 to 4326)
I don't have a coordinate in meters but I have a distance in meters which I want to convert into degrees
So that my oracle query looks like
SELECT * FROM TABLE1
WHERE SDO_WITHIN_DISTANCE(GEOMETRY, MDSYS.SDO_GEOMETRY(2001, 4326, SDO_POINT_TYPE(5.16, 52.21, NULL), NULL,NULL), 'distance=0.12234345673475345') = 'TRUE'
Where 0.12234345673475345 is just a random number from my keyboard ;-)
Instead of
WHERE SDO_WITHIN_DISTANCE(GEOMETRY, MDSYS.SDO_GEOMETRY(2001, 4326, SDO_POINT_TYPE(5.16, 52.21, NULL), NULL,NULL), 'distance=25000') = 'TRUE'
The second query results always in all records from the table because 25000 degrees as a distance means somewhere far into the universe i guess
So the key to my question is how to convert 25 kilometers into a degree like distance so my query understands what I want.
Hope you have an answer for me.
Cheers Kris
-----Original Message-----
From: Thomas Maschler [mailto:thomas.maschler at gmx.net]
Sent: Friday, March 13, 2009 3:00 PM
To: Kris Geusebroek
Subject: Re: [OpenLayers-Users] How to convert from meters to degrees for CQL_FILTER DWITHIN
Hi Kris
have a look here
http://www.uwgb.edu/dutchs/UsefulData/UTMFormulas.htm
But why don't you change the projection to UTM?
If you are using Mapserver as a WMS Server you can do this even in the
mapfile without toughing your data in the database.
Regards
Thomas
Kris Geusebroek a écrit :
> Hi all,
> I'm using a CQL_FILTER on one of my WMS layers to get all geometries
> within a certain distance.
> Problem is that the distance is specified in meters (or kilometers)
> but the layer in Oracle Spatial is specified in SRID 4326 (WGS84)
> So the distance is measured at Oracle level in degrees instead of in
> meters.
> How can I convert the amount of meters to degrees to supply oracle
> with the right information?
> Thanks in advance
> *Kris Geusebroek***
> Consultant
> cid:image001.jpg at 01C7E4CB.5BC48BD0
> Email: kgeusebroek at xebia.com <mailto:kgeusebroek at xebia.com>__
> Tel: +31 (0)35 538 1921
> Fax: +31 (0)35 538 1922
> Mobile: +31 (0)6 30 697 223
> http://www.xebia.com <http://www.xebia.fr/>
> Utrechtseweg 49
> 1213 TL Hilversum
> The Netherlands
> *Xebia Blog !* http://blog.xebia.com/
> *Xebia Podcast!* http://podcast.xebia.com/
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
