[OpenLayers-Users] OpenLayers.Layer.WMS and
OpenLayers.Layer.MapServer - variable substitution?
Christopher Schmidt
crschmidt at metacarta.com
Sun Mar 15 00:29:49 EDT 2009
On Sun, Mar 15, 2009 at 09:46:47AM +0700, Ben Madin wrote:
> Hello List,
> I wonder if you can help me then,
> On 13/03/2009, at 9:08 PM, Christopher Schmidt wrote: # apologies if I
> have cut this out incorrectly...
> >>>Please don't use Layer.MapServer unless you have to. It is really
> >>>only
> >>>there for pople who are uanble to configure the server side of their
> >>>MapSever to act as a WMS, and it will cause you more pain than you
> >>>will
> >>>gain.
> I have a mapserver layer, and it is using dates from the html page
> (start & end) as parameters for the postgis query of points.
> in my mapserver layer, I use the %start% & %end% variable
> substitution to only capture the points in the window I am interested
> in.
> I looked at the above advice, but I can't get the same substitution to
> work using the WMS setup.
The WMS layer capitalizes all key names, so you can change it to
"%START%" and it will work.
> Should I be able to do this, am I missing something, or is there
> another way around doing this?
> Or is this a good example of continuing to use mapserver?
If you have need for "?start=" to work instead of ?START=, then you
would need MapServer to continue to be able to do that. If you don't
need that, or you can change other clients, then you could use a
Layer.WMS and change your mapfile.
-- Chris
> cheers
> Ben
> Ben Madin
> AusVet Animal Health Services
> P.O. Box 5467
> Broome WA 6725
> Australia
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> e : ben at ausvet.com.au
> AusVet's website: http://www.ausvet.com.au
> This transmission is for the intended addressee only and is
> confidential information. If you have received this transmission in
> error, please delete it and notify the sender. The contents of this
> email are the opinion of the writer only and are not endorsed by
> AusVet Animal Health Services unless expressly stated otherwise.
> Although AusVet uses virus scanning software we do not accept
> liability for viruses or similar in any attachments.
Christopher Schmidt
MetaCarta
