[OpenLayers-Users] sample points outside the map
Andreas Hocevar
ahocevar at opengeo.org
Mon Mar 16 05:24:50 EDT 2009
You can render vectors outside a map. If you are using ExtJS, or to
see how to do that, you may want to have a look at
http://projects.opengeo.org/styler/browser/trunk/lib/Styler/widgets/FeatureRenderer.js
This code is part of OpenGeo's styler application (see
http://styler.opengeo.org/trunk/).
Regards,
Andreas.
On Fri, Feb 27, 2009 at 5:09 PM, Garthan <lancelot at inetnebr.com> wrote:
> For vector points which may be styled for instance as colored stars or
> regular polygons I would like to be able to render well a side bar of
> buttons (a style selection legend) which correspond to a styleMap, do I need
> to create a second map for this purpose? Is there any easier way of doing
> this or am I making things too hard?
> View this message in context: http://n2.nabble.com/sample-points-outside-the-map-tp2396529p2396529.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
