[OpenLayers-Users] Cluster Strategy WKT Vectors - not clustering
Andreas Hocevar
ahocevar at opengeo.org
Mon Mar 16 08:11:14 EDT 2009
there are several things wrong in your code.
if what you pasted below is your code, then you should get JavaScript
errors because you messed up the braces:
On Tue, Mar 3, 2009 at 5:21 PM, RFeagin
<ryan.feagin at peachtreegeographics.com> wrote:
> I am having problems with getting a clustering strategy to work on my vector
> layer. Here is my layer definition...
> vResultsLayer = new OpenLayers.Layer.Vector("Results"),
> { strategies: [new OpenLayers.Strategy.Fixed(),
> new OpenLayers.Strategy.Cluster()],
> 'sphericalMercator': true,
> styleMap: new OpenLayers.StyleMap({
> "default": style,
> "select": {
> fillColor: "#8aeeef",
> strokeColor: "#32a8a9"
This should read
vResultsLayer = new OpenLayers.Layer.Vector("Results",
"default": style,
"select": {
> and here is my code that creates the features...
> getWKT_Results: function() {
> respWKT = OpenLayers.Request.GET({
> url: "Map_GetQueryResult.ashx?" + guid(),
> success: function(request) {
> wkt = new OpenLayers.Format.WKT({
> 'internalProjection': new
> OpenLayers.Projection("EPSG:900913"),
> 'externalProjection': new
> OpenLayers.Projection("EPSG:4326")
> format = new OpenLayers.Format.XML();
> var xmlParser = format.read(respWKT.responseText);
> var featureNodes = format.getElementsByTagNameNS(xmlParser,
> '*', 'QueryResults');
> var ftrArray = new Array();
> for (var i = 0; i < format.getElementsByTagNameNS(xmlParser,
> '*', 'QueryResults').length; i++) {
> try {
> ftrArray.push(wkt.read(format.getElementsByTagNameNS(featureNodes[i], '*',
> 'WKT')[0].text)[0]);
> ftrArray[ftrArray.length - 1].fid =
> format.getElementsByTagNameNS(featureNodes[i], '*', 'featureID')[0].text;
> catch (e) {
> test = e.toString();
> vResultsLayer .addFeatures(ftrArray);
> //try to force clustering because it isn't getting set for
> the layer for some reason
> //adding these lines did force clustering on, but caused
> "this.layer.events" error trying to unregister "beforefeaturesadded" event
> //vResultsLayer .strategies = [new
> OpenLayers.Strategy.Cluster()];
> //vResultsLayer .strategies[0].active = true;
> //vResultsLayer .strategies[0].clustering = true;
You shouldn't do this manually. Add a HTTP Protocol with a WKT Format
to your layer. See
http://www.openlayers.org/dev/examples/behavior-fixed-http-gml.html
for a similar use case. You just have to replace the Fixed strategy
with your Cluster strategy and the GML format with a WKT format.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
