[OpenLayers-Users] Cluster Strategy WKT Vectors - not clustering
Christopher Schmidt
crschmidt at metacarta.com
Mon Mar 16 10:27:01 EDT 2009
On Mon, Mar 16, 2009 at 01:11:14PM +0100, Andreas Hocevar wrote:
> You shouldn't do this manually. Add a HTTP Protocol with a WKT Format
> to your layer. See
> http://www.openlayers.org/dev/examples/behavior-fixed-http-gml.html
> for a similar use case. You just have to replace the Fixed strategy
> with your Cluster strategy and the GML format with a WKT format.
The WKT format returns a single feature, rather than a list of features,
from read(), so it can not be used with a protocol, I believe.
Even if it could, the code you are responding to pulled indidvidual
chunks of WKT out of a larger XML doc, something teh WKT parser
definitely can't do. (Though writing a custom parser in this case might
make sense.)
> Regards,
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
