[OpenLayers-Users] Cluster Strategy WKT Vectors - not clustering
Christopher Schmidt
crschmidt at metacarta.com
Mon Mar 16 10:44:23 EDT 2009
On Mon, Mar 16, 2009 at 10:27:01AM -0400, Christopher Schmidt wrote:
> On Mon, Mar 16, 2009 at 01:11:14PM +0100, Andreas Hocevar wrote:
> > You shouldn't do this manually. Add a HTTP Protocol with a WKT Format
> > to your layer. See
> > http://www.openlayers.org/dev/examples/behavior-fixed-http-gml.html
> > for a similar use case. You just have to replace the Fixed strategy
> > with your Cluster strategy and the GML format with a WKT format.
> The WKT format returns a single feature, rather than a list of features,
> from read(), so it can not be used with a protocol, I believe.
> Even if it could, the code you are responding to pulled indidvidual
> chunks of WKT out of a larger XML doc, something teh WKT parser
> definitely can't do. (Though writing a custom parser in this case might
> make sense.)
http://docs.openlayers.org/library/formats.html#creating-custom-formats
is a bit of docs on this.
> > Regards,
> > Andreas.
> > Andreas Hocevar
> > OpenGeo - http://opengeo.org/
> > Expert service straight from the developers.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
Christopher Schmidt
MetaCarta
