[OpenLayers-Users] Adding Text to map.... possible?
plen
peteralen at earthlink.net
Fri Mar 20 15:39:34 EDT 2009
Andreas,
Thanks for the reply. I am happy to hear that others have thought of this
type of capability. I will look for the functionality in later OL versions.
Thanks again - Peter
Andreas Hocevar-2 wrote:
> Hi Peter,
> On Fri, Mar 20, 2009 at 1:16 AM, plen <peteralen at earthlink.net> wrote:
>> I am using the OpenLayers drawing controls to add points, lines, and
>> polygons. Our customer would like to also add text to the map, in
>> addition
>> to the other objects. This would allow the user to add some text (ex.
>> "Drive straight on this road") and place it on the map (pin it to a geo
>> coordinate). I have not seen anything that would indicate that this is
>> possible but I wanted to throw it out there to see if I may have missed a
>> possible solution.
> There is a patch providing this functionality which needs some more
> work: http://trac.openlayers.org/ticket/1895
> I am currently working on it to make the feature available in the 2.8
> release of OpenLayers, which is scheduled for April.
> Regards,
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Adding-Text-to-map....-possible--tp2506277p2510801.html
