[OpenLayers-Users] Adding Text to map.... possible?
ABateman
webadmin at lacmin.org
Fri Mar 20 17:43:24 EDT 2009
Hi Peter,
Couldn't you use a Marker's layer - like the markersTextLayer example to do
this?
-Anita
plen wrote:
> Hello,
> I am using the OpenLayers drawing controls to add points, lines, and
> polygons. Our customer would like to also add text to the map, in
> addition to the other objects. This would allow the user to add some text
> (ex. "Drive straight on this road") and place it on the map (pin it to a
> geo coordinate). I have not seen anything that would indicate that this
> is possible but I wanted to throw it out there to see if I may have missed
> a possible solution.
> Thanks - Peter
View this message in context: http://n2.nabble.com/Adding-Text-to-map....-possible--tp2506277p2511313.html
